RG-AP180P-L Bezprzewodowe - 1
RG-AP180P-L Bezprzewodowe - 2
RG-AP180P-L Bezprzewodowe - 3
RG-AP180P-L Bezprzewodowe - 4
RG-AP180P-L Bezprzewodowe - 5
RG-AP180P-L Bezprzewodowe - 6
RG-AP180P-L Bezprzewodowe - 7
RG-AP180P-L Bezprzewodowe - 8
RG-AP180P-L Bezprzewodowe - 9
RG-AP180P-L Bezprzewodowe - 10
RG-AP180P-L, Wi-Fi 6 Dual-Radio 2.976 Gbps Wall Plate AP (PoE Passthrough)
High-density small-sized scenarios covering star hotels, enterprise VIP offices, and apartments
  • Flat Rear Panel, Easy Installation on Any Wall in All Countries
  • 2.5 Gbps Uplink Port, Achieving Ultra-High Speed Access in Rooms
  • PoE Out for IP Phones and Other IoT Devices
Wall Plate AP for All Countries
Ruijie Wall Plate Wireless AP RG-AP180P-L
Appearance
Scenario
Wi-Fi 6
AX3000
Universal Mounting Kit
PoE Out
Free Cloud Management
Flat Rear Panel,
Innovative rear panel,Simple wall mounting
AX3000 chip, increasing data transmission volume
2.976 Gbps, smoother experiences
PoE out on LAN1, one cable for data and power transmission
Plug-and-play IP phones, no service interruption in a power failure
Soaring transmission rate, Superior Internet experience
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP180P-L
Unit dimensions
(W x H x D)
86 mm x 170 mm x 43 mm ( 3.4 in × 6.7 in × 1.7 in)
Shipping dimensions
399 mm x 367 mm x 245 mm ( 15.8 in × 14.5 in × 9.7 in)
Unit weight
Main unit: 0.3 kg (0.66 lbs)
Mounting bracket: 0.1 kg (0.22 lbs)
Shipping weight
0.54 kg (1.19 lbs)
Wall-mount (a mounting bracket is delivered with the main unit)
Compatible with 86-mm, EU, and US standard junction boxes
Elegant white
Kensington lock
RG-AP180P-L
● Radio 1: 2.4 GHz, two spatial streams, 2x2 MU-MIMO
● Radio 2: 5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz (HE20/HE40), ISM, channels 1 to 13
Radio 2, 802.11a/n/ac/ax:
Data rates
Radio 1: 2.4 GHz, 574 Mbps
● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client devices (max.)
Radio 2: 5 GHz, 2.402 Gbps
● Two spatial stream Single User (SU) MIMO for up to 2.402 Gbps wireless data rate to individual 2SS HE160 802.11ax client devices (max.)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
Built-in omnidirectional antenna
● 2 x 2.4 GHz antennas
● 2 x 5 GHz antennas
Max. antenna gain
2.4 GHz radio: 3.5 dBi
5 GHz radio: 4.5 dBi
Max. transmit power
2.4 GHz radio: 20 dBm (17 dBm per chain)
5 GHz radio: 20 dBm (17 dBm per chain)
Thailand
Power increment
Configurable in increments of 1 dBm
Radio technologies
802.11b: BPSK, QPSK, CCK
Frequency Performance
RG-AP180P-L
1 Mbps
–96 dBm
-10 dBm
–94 dBm
-10 dBm
–93 dBm
11 Mbps
-10 dBm
6 Mbps
19 dBm
24 Mbps
17 dBm
36 Mbps
17 dBm
54 Mbps
–74 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
12 dBm
–58 dBm
17 dBm
12 dBm
6 Mbps
24 Mbps
17 dBm
36 Mbps
17 dBm
–78 dBm
54 Mbps
15 dBm
–72 dBm
14 dBm
–67 dBm
17 dBm
14 dBm
–64 dBm
13 dBm
17 dBm
13 dBm
–57 dBm
13 dBm
–56 dBm
12 dBm
–58 dBm
17 dBm
12 dBm
12 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
15 dBm
12 dBm
–50 dBm
Bluetooth Radio
RG-AP180P-L
Bluetooth 5.1
Max. antenna gain
Max. transmit power
10 dBm
Receive sensitivity
–88 dBm (@BLE)
RG-AP180P-L
Uplink:
1 x 100/1000/2500Base-T Ethernet port with auto-negotiation, compliant-with IEEE 802.3af/802.3at standard (PoE/PoE+). When powered by 802.3af PoE, LAN 1 cannot supply power to an attached device.
Downlink:
4 x 10/100/1000Base-T Ethernet ports with auto-negotiation. LAN 1 supports 48 V/10 W power supply to an attached device.
1 x Micro USB console port
RG-AP180P-L
● PoE input over PoE-in port: The power source equipment (PSE) complies with IEEE 802.3af/at standard (PoE/PoE+).
External power supply
LAN 1 supports 48 V/10 W PoE output to an attached device.
Max power consumption
Max power consumption: 25 W
● DC powered: 25 W
● PoE powered (802.3af): 15 W
● Idle mode: 8 W
RG-AP180P-L
Operating temperature: 0°C to 40°C (–32°F to +104°F)
Note: At an altitude between 3,000 m (9,843 ft) and 5,000 m (16,404 ft), every time the altitude increases by 220 m (722 ft), the maximum temperature decreases by 1°C (1.8°F).
Environment standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
RG-AP180P-L
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
RG-AP180P-L
RGOS11.9(6)W3B3 or higher
RG-AP180P-L
Recommended max number of active devices per AP
Max number of associated clients
256
Note
Max. number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
Security and Authentication
RG-AP180P-L
PSK, web, 802.1x, WPA, WPA2, and WPA3 authentication
WPA3-Personal (SAE) and WPA3-Personal hybrid
QR code-based guest authentication
SMS authentication
MAB authentication
Data encryption: WPA-TKIP, WPA-PSK, WPA2-AES, WEP (64/128-bit)
Dynamic ACL assignment
Routing and Switching
RG-AP180P-L
IP service
IPv6 basics
IPv6 DHCP Client
RG-AP180P-L
NTP server and NTP client
Fault inspection and alarm
Web-based management (Eweb)
STA access management
Console and Telnet-based management
FTP client and TFTP client
Fat/Fit/Cloud mode switchover
RG-AP180P-L
Wi-Fi 6 dual-radio wall plate wireless access point
Up to four spatial streams
Data rate of up to 2.976 Gbps
IEEE 802.3af/at-compliant power supply and DC power supply
●    A 48 V/0.6 A power adapter needs to be purchased separately.
