RG-AP180(V3) Bezprzewodowe - 1
RG-AP180(V3) Bezprzewodowe - 2
RG-AP180(V3) Bezprzewodowe - 3
RG-AP180(V3) Bezprzewodowe - 4
RG-AP180(V3) Bezprzewodowe - 5
RG-AP180(V3) Bezprzewodowe - 6
RG-AP180(V3) Bezprzewodowe - 7
RG-AP180(V3) Bezprzewodowe - 8
RG-AP180(V3), Wi-Fi 6 Dual-Radio 2.976 Gbps Indoor Wall Plate Access Point, 1Gbps Ethernet Port
RG-AP180(V3)
Appearance
Scenario
Dual-Radio
2.4G/5G
4 Spatial Streams
PoE Power Supply
Max. Combined Rate
2.976 Gbps
Power Consumption
10 W
Max. Concurrent STAs
1024
Upgraded to Wi-Fi 6
2.976
Gbps
High Concurrency
Low Latency
20 ms.
High Security
wireless connection.
High Speed
Authentication
PSK、WPA、WPA2、WAP
etc. (store)
802.1XAuthentication
(enterprise-class)
Web Authentication
(enterprise-class)
SM-based Authentication
MAC Authentication Bypass
Go to WIS->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
RG-AP180(V3)
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in omnidirectional antennas, the max. antenna gain is 2 dBi.
● 5 GHz: two built-in omnidirectional antennas, the max. antenna gain is 2 dBi.
● One integrated vertically polarized omnidirectional antenna, the max. antenna gain is 2 dBi.
Uplink: 1 x 10/100/1000Base-T auto-negotiation RJ45 Ethernet port, 802.3af/at-compliant PoE
Downlink: 4 x 10/100/1000Base-T auto-negotiation RJ45 Ethernet ports
1 x Bluetooth 5.0
● CAPWAP tunnel timeout
● Specific AP locating
Shipping: 96 mm x 128 mm x 59 mm (3.78 in. x 5.04 in. x 2.33 in.)
Main unit: 0.22 kg (0.49 lbs)
Shipping: 0.31 kg (0.68 lbs)
Mounting in 86 mm x 86 mm junction box
● DC power: 10 W
● 802.3at (PoE+): 10 W
● 802.3af (PoE): 10 W
● Idle mode: 3.5 W
At an altitude between 3,000 m (9,842.52 ft.) and 5,000 m (16,404.20 ft.), every time the altitude increases by 166 m (546 ft.), the maximum temperature decreases by 1°C (1.8°F).
Mean Time
Between Failure
(MTBF)
RAM: 2 GB
SPI: 8 MB
Nand: 128 MB
● Max. transmit power: +21 dBm (126 mW)
● Minimum transmit power: +8 dBm (6.31 mW)
Note: The transmit power adjusted in percentage. The transmit power is limited by local regulatory requirements.
RG-AP180(V3)
17 dBm
–90 dBm
15 dBm
–87 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
12 dBm
–58 dBm
12 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
15 dBm
24 dBm
–88 dBm
–63 dBm
15 dBm
12 dBm
–58 dBm
12 dBm
12 dBm
–52 dBm
5 GHz, 802.11ax (HE160)
–75 dBm
9 dBm
–47 dBm
RG-AP180(V3)
RGOS11.9(6)B9 or later
Max. number of BSSIDs
16 (up to 8 BSSIDs per radio)
Max. number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK, UPSK and web authentication
Data encryption: WEP (64/128 bits), WPA (TKIP), WPA-PSK, WPA2 (AES), WPA3-Enterprise, WPA3-Individual
VLAN-based user isolation
Dynamic Policy
CoA/DM
MAC address table size: 1,024
Max. number of static MAC addresses: 1,024
Max. number of filtered MAC addresses: 1,024
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Max. number of VLANs: 4,094
VLAN ID range: 1–4,094
ARP entry aging and proxy ARP
Max. number of ARP entries: 1,024
Max. number of IPv4 addresses configured on each Layer 3 interface: 200
NAT, FTP ALG and DNS ALG
Max. number of static IPv4 routes: 1,024
Max. number of static IPv6 routes: 1,000
NTP server and NTP client
When the AP works in cloud mode, it can be managed through Ruijie Cloud.
RG-AP180(V3)
RG-AP180(V3)
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, IEC 62368-1, EN 62368-1, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, and EN IEC 62311
RG-AP180(V3)
