RG-AP180 Bezprzewodowe - 1
RG-AP180 Bezprzewodowe - 2
RG-AP180 Bezprzewodowe - 3
RG-AP180 Bezprzewodowe - 4
RG-AP180 Bezprzewodowe - 5
RG-AP180 Bezprzewodowe - 6
RG-AP180 Bezprzewodowe - 7
RG-AP180 Bezprzewodowe - 8
RG-AP180 Bezprzewodowe - 9
RG-AP180 Bezprzewodowe - 10
RG-AP180, Wi-Fi 6 Dual Radio 1.775 Gbps Indoor Wall Plate Wireless AP
Recommended for indoor scenarios such as dormitories, offices, hotels, stores, and classrooms
  • Multi-service Linkage, All-in-One for Office Scenarios
  • 1.775 Gbps Ultra-Fast Speed with Wi-Fi 6
  • Full-Scenario Enterprise-class Authentication for Enhanced Security
  • Ruijie Cloud Management, Intelligent Optimization, and Easy O&M
RG-AP180 Indoor Wall Plate Wireless Access Point
Scenario
2.4 GHz and 5 GHz Dual Radios
Four Spatial Streams
PoE and DC Power Input
Combined Rate Up to 1.775 Gbps
Max. Power Consumption of 10 W
RG-AP180 supports IPsec VPN, NAT and PPPoE. In addition to delivering wireless access services in office areas, this AP can act as a VPN gateway to establish a dedicated tunnel for the office network, creating a two-in-one network between branch office and headquarters office to improve security.
1.775
Gbps
High speed
With 1024-QAM modulation, the data transmission rate is 25% higher than 802.11ac.
High concurrency
OFDMA and MU-MIMO are introduced to ensure stable access of multiple STAs
High security
The next-generation wireless encryption protocol WPA3 greatly improves the
Low latency
OFDMA is applied to transmit data to multiple STAs simultaneously. The latency is as low as 20 ms.
Remote monitoring
Remote Wi-Fi management
Cloud portal authentication
RG-AP180
Unit dimensions
(W x H x D)
In-wall: 86 mm x 116 mm x 19 mm (3.39 in. x 4.57 in. x 0.75 in.)
Above-wall: 86 mm x 116 x mm x 24 mm (3.39 in. x 4.57 in. x 0.94 in.)
128 mm x 96 mm x 59 mm (5.04 in. x 3.78 in. x 2.32 in.)
0.22 kg (0.49 lbs)
0.31 kg (0.68lbs)
Wall-mount
Compatible with 86-mm and EU standard junction boxes (if you want to use the US standard junction box, purchase an RG-AP180-MNT mounting bracket separately)
Elegant white
RG-AP180
Operating frequencies
Radio 1: 802.11b/g/n/ax
● 2.400 GHz to 2.4835 GHz, ISM, channels 1 to 13
Radio 2: 802.11a/n/ac/ax
Data rates
Radio 1: 2.4 GHz, 574 Mbps
● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client devices (max.)
Radio 2: 5 GHz, 1.201 Gbps
● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client devices (max.)
● Two spatial stream Multi-User (MU) MIMO for up to 1.201 Gbps wireless data rate to up to two 1SS HE80 802.11ax DL-MU-MIMO capable client devices simultaneously (max.)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
● 802.11ax: 8.6 to 1,200 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE80)
packet aggregation
Built-in intelligent antenna (two 2.4 GHz antennas and two 5 GHz antennas)
Max. antenna gain
2.4 GHz radio: 0.9 dBi
5 GHz radio: 0.9 dBi
Max. transmit power
Thailand
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
Frequency Performance
RG-AP180
17 dBm
–90 dBm
15 dBm
–87 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–77 dBm
15 dBm
–64 dBm
12 dBm
–58 dBm
12 dBm
–78 dBm
15 dBm
–72 dBm
15 dBm
–67 dBm
15 dBm
–64 dBm
13 dBm
13 dBm
–57 dBm
13 dBm
12 dBm
–58 dBm
12 dBm
12 dBm
–52 dBm
Bluetooth Radio
RG-AP180
Bluetooth 5.0
Max. antenna gain
Max. transmit power
10 dBm
Receive sensitivity
–88 dBm (@BLE)
RG-AP180
Uplink:
1 x 10/100/1000Base-T Ethernet port with auto-negotiation, compliant-with IEEE 802.3af/802.3at standard (PoE/PoE+).
Downlink:
4 x 10/100/1000Base-T Ethernet ports with auto-negotiation
1 x Micro USB console port (under the decorative cover)
RG-AP180
● 12 V DC/1 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
● PoE input over the PoE-in port: The power source equipment (PSE) complies with the IEEE 802.3af standard. The IEEE 802.3at (PoE+) standard is backward compatible with the IEEE 802.3af (PoE) standard.
External power supply
Max power consumption: 10 W
● DC powered: 10 W
● PoE powered (802.3af): 10 W
● Idle mode: 3.3 W
RG-AP180
Operating temperature: –10°C to +50°C (+14°F to +122°F)
Storage temperature: –40°C to+ 70°C (–40°F to +158°F)
Note: At an altitude between 3,000 m (9,843 ft.) and 5,000 m (16,404 ft.), every time the altitude increases by 220 m (722 ft.), the maximum temperature decreases by 1°C (1.8°F).
Environment standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
RG-AP180
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
RG-AP180
RGOS11.9(6)W3B3 or later
RG-AP180
Recommended max number of active devices per AP
Max number of associated clients
256
Note
Max. number of BSSIDs
16 (up to 8 BSSIDs per radio)
RG-AP180
PSK, web, and 802.1X authentication
QR code-based guest authentication, SMS authentication, MAB authentication (used with the RG-WS series wireless access controller)
Data encryption: WEP (64/128-bit), WPA-TKIP, WPA-PSK, WPA2-AES, WPA3
Dynamic ACL assignment
RG-AP180
NAT ALG FTP and NAT ALG DNS
IPv6 basics
RG-AP180
NTP server and NTP client
Fault inspection and alarm
Web-based management (Eweb)
Console ,Telnet-based management, and TFTP client
Fat/Fit/Cloud mode switchover
RG-AP180
802.11ax dual-radio wall plate wireless access point
Up to four spatial streams
Data rate of up to 1.775 Gbps
●    A 12 V/1 A power adapter needs to be purchased separately.
RG-AP180-MNT
(Optical) Mounting bracket for the US standard junction box. Each set contains 10 pieces.
