RG-AP680P-L Bezprzewodowe - 1
RG-AP680P-L Bezprzewodowe - 2
RG-AP680P-L Bezprzewodowe - 3
RG-AP680P-L Bezprzewodowe - 4
RG-AP680P-L Bezprzewodowe - 5
RG-AP680P-L Bezprzewodowe - 6
RG-AP680P-L, Wi-Fi 6 Dual-Radio 5.951 Gbps Outdoor Access Point, Omnidirectional Antennas
Outdoor scenarios in general education, SME, energy, business, government, and healthcare sectors
  • 10G optical port for flexible networking
  • Built-in omnidirectional antennas, wide Wi-Fi coverage
  • 5.951 Gbps high speed with 160 MHz band
  • Industrial-grade product design, IP68 rating, 6 kV lightning protection
Key Specification View More
Product Overview
Product Highlights
Wi-Fi 6 certification
Up to 1024 client connections
RG-AP680P-L
Unit dimensions
470 mm x 410 mm x 170 mm (18.50 in. x 16.14 in. x 6.69 in.)
Main unit: 3.3 kg (7.28 lbs)
6.5 kg (14.33 lbs)
Wall or pole mounting (a mounting bracket is delivered with the main unit)
RG-AP680P-L
Operating frequencies
Radio 1: 802.11b/g/n/ax
Radio 2: 802.11a/n/ac/ax
Data rates
Radio 1: 2.4 GHz, 1.147 Gbps
● Four spatial stream Single User (SU) MIMO for up to 1.147 Gbps wireless data rate to individual 4SS HE40 802.11ax client devices (max.)
Radio 2: 5 GHz, 4.804 Gbps
● Four spatial stream Single User (SU) MIMO for up to 4.804 Gbps wireless data rate to individual 4SS HE160 802.11ax client devices (max)
● Four spatial stream Multi-User (MU) MIMO for up to 4.804 Gbps wireless data rate to up to four 1SS HE160 802.11ax DL-MU-MIMO capable client devices simultaneously (max)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
Max. antenna gain
The downtilt angle for the maximum gain is roughly 35 degrees.
With reference to the pattern of each antenna of the MIMO radios, the maximum gain of the effective per-antenna pattern is 4.9 dBi in 2.4 GHz and 3.9 dBi in 5 GHz.
Max. transmit power
Note: The transmit power is subject to local regulatory requirements.
Thailand
2.4 GHz to 2.4835 GHz: 20 dBm
Power increment
Increment of 1 dBm
Radio technologies
802.11b: BPSK, QPSK, CCK
Frequency Performance
RG-AP680P-L
2.4 GHz 802.11b
24 dBm
–94 dBm
24 dBm
–91 dBm
23 dBm
–90 dBm
22 dBm
–88 dBm
2.4 GHz 802.11g
24 dBm
–89.5 dBm
–83 dBm
–79 dBm
21 dBm
–73 dBm
2.4 GHz 802.11n (HT20)
24 dBm
–86 dBm
21 dBm
–68 dBm
2.4 GHz 802.11n (HT40)
24 dBm
–83 dBm
21 dBm
–65 dBm
2.4 GHz 802.11ax (HE20)
24 dBm
–86 dBm
19 dBm
–68 dBm
2.4 GHz 802.11ax (HE40)
24 dBm
–83 dBm
19 dBm
–65 dBm
5 GHz 802.11a
23 dBm
–89.5 dBm
22 dBm
–83 dBm
22 dBm
–79 dBm
–73 dBm
5 GHz 802.11n (HT20)
23 dBm
–86 dBm
–68 dBm
5 GHz 802.11n (HT40)
23 dBm
–83 dBm
–65 dBm
5 GHz 802.11ac (VHT20)
23dBm
–86 dBm
19 dBm
–61 dBm
5 GHz 802.11ac (VHT40)
23 dBm
–83 dBm
19 dBm
–57 dBm
5 GHz 802.11ac (VHT80)
23 dBm
–80 dBm
19 dBm
5 GHz 802.11ax (HE20)
23 dBm
–86 dBm
16 dBm
–58 dBm
5 GHz 802.11ax (HE40)
23 dBm
–83 dBm
16 dBm
–54 dBm
5 GHz 802.11ax (HE80)
23 dBm
–80 dBm
16 dBm
–52 dBm
5 GHz 802.11ax (HE160)
23 dBm
–77 dBm
16 dBm
–49 dBm
Bluetooth Radio
RG-AP680P-L
Bluetooth 5.1
Max. antenna gain
2 dBi
Max. transmit power
10 dBm
Receive sensitivity
–88 dBm (@BLE)
RG-AP680P-L
Uplink:
1 x 10GE optical port, compatibility with 1GE and 2.5GE
1 x 100/ 1000/2500/5000Base-T RJ45 Ethernet port with auto-negotiation
● Intelligent MDI/MDIX recognition for automatic MDI/MDIX crossover and automatic identification of connected network cable types
● 802.3az EEE
Downlink:
1 x 100/1000Base-T RJ45 Ethernet port with auto-negotiation
● 802.3az EEE
3 x single-color RSSI LEDs
RG-AP680P-L
● When powered by 802.3af (PoE), the AP starts up normally.Bluetooth and GPS work properly; all RF cards do not work; external power supply of the PSE is disabled.
Max. power consumption: 40 W
● Idle mode: 10 W
RG-AP680P-L
Operating humidity: 0% to 100% RH (non-condensing)
Storage humidity: 0% to 100% RH (non-condensing)
Corrosion protection
EN300 0019 Class C
IP68
RG-AP680P-L
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
IEC 60950-22
Applicable Software Version
RG-AP680P-L
RGOS11.9(6)W3B6 or higher
RG-AP680P-L
Recommended max number of active devices per AP
Max number of associated clients
1024
Note
Max. number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP680P-L
PSK and web authentication
QR code-based guest authentication (used with the RG-WS series wireless access controller)
Data encryption: WPA-TKIP, WPA-PSK, WPA2-AES, WPA3, WEP (64/128-bit)
Dynamic ACL assignment
Routing and Switching
RG-AP680P-L
IP service
NAT, FTP ALG, DNS ALG
IPv6 basics
RG-AP680P-L
Fault inspection and alarm
Web-based management (Eweb)
Telnet, SSH, SNMP and TFTP-based management
Fat/Fit/Cloud mode switchover
RG-AP680P-L
Up to eight spatial streams
