RG-AP840-L Bezprzewodowe - 1
RG-AP840-L Bezprzewodowe - 2
RG-AP840-L Bezprzewodowe - 3
RG-AP840-L Bezprzewodowe - 4
RG-AP840-L Bezprzewodowe - 5
RG-AP840-L Bezprzewodowe - 6
RG-AP840-L Bezprzewodowe - 7
RG-AP840-L Bezprzewodowe - 8
RG-AP840-L Bezprzewodowe - 9
RG-AP840-L Bezprzewodowe - 10
RG-AP840-L, Wi-Fi 6 Dual-Radio 5.378 Gbps Indoor AP
RG-AP840-L
5 Gbps SFP &
RJ45 Combo Port
PoE/DC Power Supply
Ceiling/Wall Mounting
Free Cloud Management
Wi-Fi 6 AX5400
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
160 MHz and 6 Spatial Streams
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP840-L
Unit dimensions
230 mm x 230 mm x 51 mm (9.06 in x 9.06 in x 2.01 in)
284 mm x 262 mm x 124 mm (11.18 in x 10.31 in x 4.88 in)
Main unit: 1.0 kg (2.20 lbs)
1.25 kg (2.76 lbs)
RG-AP840-L
Operating frequencies
802.11b/g/n/ax:
802.11a/n/ac/ax:
Data rates
5 GHz radio:
● Four spatial stream Single User (SU) MIMO for up to 4.804 Gbps wireless data rate to individual 4SS HE160 802.11ax client devices (max.)
● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client devices (typical)
● Four spatial stream Multi User (MU) MIMO for up to 4.804 Gbps wireless data rate to up to four 1SS or two 2SS HE160 802.11ax DL-MU-MIMO capable client devices simultaneously (max.)
● Four spatial stream Multi User (MU) MIMO for up to 2.402 Gbps wireless data rate to up to four 1SS or two 2SS HE80 802.11ax DL-MU-MIMO capable client devices simultaneously (typical)
2.4 GHz radio:
● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to 2SS HE40 802.11ax client devices (max.)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
● 802.11ax: 8.6 to 4,803 (MCS0 to MCS11, NSS = 1 to 4, HE20 to HE160)
Packet aggregation
Max. antenna gain
4.8 dBi in 2.4 GHz and 5.1 dBi in 5 GHz
The downtilt angle for the maximum gain is roughly 35 degrees.
With reference to the pattern of each antenna of the MIMO radios, the maximum gain of the effective per-antenna pattern is 3.8 dBi in 2.4 GHz and 4.6 dBi in 5 GHz.
Max. transmit power
Thailand
Power increment
Radio technologies
802.11b: BPSK, QPSK, and CCK
Wi-Fi Radio
Frequency Performance
RG-AP840-L
24 dBm
–96 dBm
24 dBm
–95 dBm
–93 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–62 dBm
24 dBm
–88 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–68 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–63 dBm
24 dBm
24 dBm
–90 dBm
24 dBm
–86 dBm
–56 dBm
24 dBm
–83 dBm
24 dBm
5 GHz, 802.11ax (HE160)
–81 dBm
–51 dBm
Bluetooth Radio
RG-AP840-L
Bluetooth 5.1
Max. antenna gain
Max. transmit power
10 dBm (Class 1)
Receive sensitivity
–98 dBm
RG-AP840-L
1 x 100/ 1000/2500/5000Base-T RJ45 Ethernet port with auto-negotiation
● Auto MDI/MDIX crossover
● 802.3az EEE
1 x 5GE combo SFP port, compatible with 1GE and 2.5GE
1 x 10/100/1000Base-T RJ45 Ethernet port with auto-negotiation
● 802.3az EEE
USB 3.0 (Type-A connector)
RG-AP840-L
External power supply
● The LAN 2 port can source 48 V/12.95 W power to a unit.
Max power consumption: 40 W
● DC powered: 40 W
● Idle mode: 10.3 W
RG-AP840-L
Operating temperature: –10°C to 50°C (14°F to 122°F)
Note: At an altitude between 3,000 m (9,843 ft) and 5,000 m (16,404 ft), every time the altitude increases by 220 m (722 ft), the maximum temperature decreases by 1°C (1.8°F).
Operating humidity: 5% to 95% (non-condensing)
Storage humidity: 5% to 95% (non-condensing)
Environment standard
Operating environment: ETS 300 019 Class 3.2
Storage and shipment environment: ETS 300 019 Classes 1.2 and 2.3
RG-AP840-L
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
Applicable Software Version
RG-AP840-L
RGOS11.9(6)W3B3 or higher
RG-AP840-L
Recommended max number of active devices per AP
Max number of associated clients
1024
Note
Max. number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP840-L
PSK and web authentication
QR code-based guest authentication, SMS authentication, MAB authentication (used with the RG-WS series wireless access controller)
Data encryption: WEP (64/128 bits), WPA-TKIP, WPA-PSK, WPA2-AES, WPA3-Enterprise, WPA3-Individual
Dynamic ACL assignment
Routing and Switching
RG-AP840-L
IP service
NAT, FTP ALG, DNS ALG
IPv6 basics
IPv6 DHCP Client
PPPoE Client
RG-AP840-L
Fault inspection and alarm
Web-based management
Telnet, SSH, SNMP, and TFTP-based management
Fat/Fit/Cloud mode switchover
RG-AP840-L
Up to six spatial streams
Data rate of up to 5.378 Gbps
Fat/Fit/cloud mode switchover
