RG-AP820-L(V3) Bezprzewodowe - 1
RG-AP820-L(V3) Bezprzewodowe - 2
RG-AP820-L(V3) Bezprzewodowe - 3
RG-AP820-L(V3) Bezprzewodowe - 4
RG-AP820-L(V3) Bezprzewodowe - 5
RG-AP820-L(V3) Bezprzewodowe - 6
RG-AP820-L(V3) Bezprzewodowe - 7
RG-AP820-L(V3) Bezprzewodowe - 8
RG-AP820-L(V3) Bezprzewodowe - 9
RG-AP820-L(V3) Bezprzewodowe - 10
RG-AP820-L(V3) Bezprzewodowe - 11
RG-AP820-L(V3), Wi-Fi 6 AX3000 Indoor AP
Indoor scenarios for higher education, government, general education, finance, and business sectors.
  • 2.5 Gbps SFP Port, Multi-Gigabit Mesh Networking
  • Next-generation AX3000 chip, supporting 160 MHz 2.976 Gbps
  • Next-generation Wi-Fi 6 technology, higher concurrency, lower latency
  • Unified cloud management, intelligent tuning, easy O&M
Ruijie Wi-Fi 6 High Performance Indoor AP
2.5 Gbps SFP Port
Next-Generation AX3000 Chip
Max. Rate of 2.976 Gbps
Bluetooth 5.1
2.5 Gbps SFP Port, Multi-Gigabit Connectivity
The 2.5 Gbps SFP port unleashes the performance of bandwidth for multi-gigabit connectivity.
2.976 Gbps Ultra-Fast Speed with 160 MHz Band
The next-generation AX3000 chip supports 160 MHz band, doubling the Wi-Fi speed.
Wi-Fi 6 dual radios enable a combined rate of 2.976 Gbps, delivering smooth video streaming, instant audio messaging, and file download in seconds.
Ultimate Speed and Capacity with Wi-Fi 6, Up To 2.976 Gbps
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP820-L(V3)
220 mm x 220 mm x 49 mm (8.66 in x 8.66 in x 1.93 in)
507 mm x 319 mm x 278 mm (19.96 in x 12.56 in x 10.94 in)
Main unit: 0.6 kg (1.33 lbs)
1.04 kg (2.29 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit)
RG-AP820-L(V3)
 Radio 1: 2.4 GHz, two spatial streams, 2x2 MU-MIMO
 Radio 2: 5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n/ax:
 2.400 GHz to 2.4835 GHz, ISM
Radio 2, 802.11a/n/ac/ax:
 5.150 GHz to 5.250 GHz, U-NII-1
 5.250 GHz to 5.350 GHz, U-NII-2A
 5.470 GHz to 5.725 GHz, U-NII-2C
 5.725 GHz to 5.850 GHz, U-NII-3/ISM
Data rates
2.4 GHz radio
 Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client devices (max.)
 Two spatial stream Single User (SU) MIMO for up to 287 Mbps wireless data rate to individual 2SS HE20 802.11ax client devices (typical)
5 GHz radio
 Two spatial stream Single User (SU) MIMO for up to 2.402 Gbps wireless data rate to individual 2SS HE160 802.11ax client devices (max.)
 Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client devices (typical)
Data rate set
2.4 GHz radio
 802.11b: 1, 2, 5.5, 11
 802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, 54
 802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40)
 802.11ax: 8.6 to 574 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE40)
5 GHz radio
 802.11a: 6, 9, 12, 18, 24, 36, 48, 54
 802.11ac: 6.5 to 1,732 (MCS0 to MCS9, NSS = 1 to 4, VHT20 to VHT160)
 802.11ax: 8.6 to 2,402 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE160)
Packet aggregation
Built-in omnidirectional antenna (two 2.4 GHz antennas and two 5 GHz antennas)
Max. antenna gain
1.7 dBi in 2.4 GHz and 2.5 dBi in 5 GHz
The downtilt angle for the maximum gain is roughly 30 degrees.
With reference to the pattern of each antenna of the MIMO radios, the maximum gain of the effective per-antenna pattern is 2.3 dBi in the 2.4 GHz radio and 2.7 dBi in the 5 GHz radio.
Max. transmit power
Thailand
Power increment
Radio technologies
802.11b: BPSK, QPSK, CCK
802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Frequency Performance
RG-AP820-L(V3)
2.4 GHz 802.11b
-91 dBm
-91 dBm
-90 dBm
-87 dBm
2.4 GHz 802.11g
-89 dBm
22 dBm
-82 dBm
22 dBm
-78 dBm
-72 dBm
2.4 GHz 802.11n (HT20)
-85dBm
19 dBm
-67 dBm
2.4 GHz 802.11n (HT40)
-82 dBm
19 dBm
-64 dBm
2.4 GHz 802.11ax (HE20)
-85 dBm
15 dBm
-58 dBm
2.4 GHz 802.11ax (HE40)
-82 dBm
15 dBm
-54 dBm
5 GHz 802.11a
-89 dBm
22 dBm
-82 dBm
22 dBm
-78 dBm
-72 dBm
5 GHz 802.11n (HT20)
-85 dBm
19 dBm
-67 dBm
5 GHz 802.11n (HT40)
-82 dBm
19 dBm
-64 dBm
5 GHz 802.11ac (VHT20)
-85 dBm
-60 dBm
5 GHz 802.11ac (VHT40)
-82 dBm
-57 dBm
5 GHz 802.11ac (VHT80)
-79 dBm
-53 dBm
5 GHz 802.11ax (HE20)
-85 dBm
-58 dBm
5 GHz 802.11ax (HE40)
-82 dBm
-54 dBm
5 GHz 802.11ax (HE80)
-79 dBm
-52 dBm
5 GHz 802.11ax (HE160)
-77 dBm
-50 dBm
Bluetooth Radio
RG-AP820-L(V3)
Bluetooth 5.1
Max. antenna gain
Max. transmit power
17 dBm (GFSK)
14 dBm (π/4-DQPSK, 8-DPSK)
Receive sensitivity
–95.5 dBm (DH5)
–95 dBm (π/4-DQPSK)
–87.5 dBm (8-DPSK)
RG-AP820-L(V3)
1 x 10/100/1000Base-T RJ45 Ethernet port with auto-negotiation
 Compliance with IEEE 802.3af standard (PoE)
 Auto MDI/MDIX crossover
 PoE-PD: 54 V DC (nominal) 802.3af/at/bt (Class 3 or higher)
 802.3az EEE
1 x 2.5GE SFP combo port, compatibility with 1GE modules, and multiplexing with 1 x 10/100/1000Base-T RJ45 Ethernet port
 Press the button for shorter than 2 seconds. Then the device restarts.
 Press the button for longer than 5 seconds. Then the device restores to factory settings.
● Note
A combo port consists of an optical Ethernet port and an electrical Ethernet port on the panel and can be used as the optical or electrical port at one time. When either of the Ethernet ports is working, the other port is automatically shut down. You can select a port type as required.
RG-AP820-L(V3)
 48 V DC/0.6 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
 PoE input over LAN 1: The power source equipment (PSE) complies with IEEE 802.3af standard (PoE).
 If both DC power and PoE are available, DC power is preferred.
Max power consumption: 12.95 W
 DC powered: 12.95 W
 PoE+ powered (802.3at): 12.95 W
 PoE++ powered (802.3bt): 12.95 W
 Idle mode: 6 W
 ● Note
When the 2.5GE SFP port of the RG-AP820-L(V3) is used as an uplink port, the port supports PoE or DC power supply. When PoE is adopted, the auto-negotiation Ethernet port (LAN/1G/PoE) serves as a PoE-in port only.
RG-AP820-L(V3)
Note: At an altitude between 3,000 m (9,843 ft) and 5,000 m (16,404 ft), every time the altitude increases by 220 m (722 ft), the maximum temperature decreases by 1°C (1.8°F).
Operating humidity: 0% to 95% RH (non-condensing)
Storage humidity: 0% to 95% RH (non-condensing)
Environment standard
Storage and operating environment: NEBS GR-63-CORE_Issue3_2006 GB/T 2423.6-1995
Security regulations
GB 4943.1, IEC 62368-1
EMC regulations
EN 300386, GB/T 19286, GB/T 17618
FCC Part 15
Radio frequency regulations
FCC Part 15E: 15.407
RG-AP820-L(V3)
EN 301 489-3
EN 301 489-17
EN 300 328
FCC Part 15
EN IEC 62311
EN 62368-1
Applicable Software Version
RG-AP820-L(V3)
RGOS11.9(6)W1B4 or higher
RG-AP820-L(V3)
Recommended max number of active devices per AP
Max number of associated clients
256
 Note
Max. number of BSSIDs
RG-AP820-L(V3)
PSK and web authentication
QR code-based guest authentication, SMS authentication, MAB authentication (used with the RG-WS series wireless access controller)
Data encryption: WPA-TKIP, WPA-PSK, WPA2-AES, WEP (64/128-bit)
Dynamic ACL assignment
Routing and Switching
RG-AP820-L(V3)
IP service
Static IPv4 address
IPv4 DHCP Client
FTP ALG and DNS ALG
IPv6 basics
IPv6 DHCP Client
PPPoE Client
LLDP-MED
LLDP-PoE
RG-AP820-L(V3)
Fault inspection and alarm
Ruijie Cloud
Web-based management (Eweb)
Telnet, SSH, and TFTP-based management
Fat/Fit/Cloud mode switchover
RG-AP820-L(V3)
Wi-Fi 6 dual-radio indoor wireless access point
Up to four spatial streams
Data rate of up to 2.976 Gbps
Compliance with IEEE 802.11a/b/g/n/ac and 802.11ax standards
RG-E-120(GE)
PSE with 1 x GE port in compliant with IEEE 802.3af standard (PoE)
