RG-N18010-XH Sieci w centrach danych - 1
RG-N18010-XH Sieci w centrach danych - 2
RG-N18010-XH Sieci w centrach danych - 3
RG-N18010-XH Sieci w centrach danych - 4
RG-N18010-XH Sieci w centrach danych - 5
RG-N18010-XH Sieci w centrach danych - 6
RG-N18010-XH Sieci w centrach danych - 7
RG-N18010-XH Sieci w centrach danych - 8
RG-N18010-XH Sieci w centrach danych - 9
RG-N18010-XH Sieci w centrach danych - 10
Parametry Kluczowe
Charakterystyka
Data Center 400GE Modular
Core Switch
RG-N18010-XH
expansion needs.
networks.
Zero Midplane
Clos Architecture
Hardware-level Redundancy,
Center Network Stability
SFUs in N+1 Redundancy Mode
efficient heat dissipation.
Supervisor Engin es in 1+1 Redundancy Mode
the switch.
Specyfikacje
RG-N18018-XH
RG-N18010-XH
442 mm x 1052 mm x 1345 mm (17.40 in. x 41.42 in. x 52.95 in.), without the cable management bracket;
442 mm x 1091 mm x 1345 mm (17.40 in. x 42.95 in. x 52.95 in.), with the cable management bracket.
442 mm x 896 mm x 708 mm (17.40 in. X 35.28 in. X 27.87 in.), without the cable management bracket;
442 mm x 935 mm x 708 mm (17.40 in. x 36.81 in. X 27.87 in.), with the cable management bracket.
31 RU
16 RU
205 kg (451.95 lbs.), with M18018XH-FAN fan modules;
186 kg (410.06 lbs.), with M18018XH-FAN III fan modules.
96.4 kg (212.53 lbs.) (Chassis that supports the M18000XH-CM supervisor module)
99 kg (218.26 lbs.) (Chassis that supports the M18000XH-CM II supervisor module)
1,290 Tbps/3,870 Tbps
645 Tbps/1,935 Tbps
691,200 Mpps
345,600 Mpps
2 x supervisor module slots
16 x line card slots
8 x switch fabric module slots
20 x power module slots
8 x line card slots
10 x power module slots
Maximum power consumption (with the M18018XH-FAN fan module): 38,900 W
Maximum power consumption (with the M18018XH-FAN III fan module): 18,000 W
Maximum power consumption (with the M18010XH-FAN fan module): 187,600 W
Maximum power consumption (with the M18010XH-FAN III fan module): 9000 W
RG-PAH3000I-F (AC input):
Rated input voltage: 100 V AC to 130 V AC, 200 V AC to 240 V AC, 50 Hz/60 Hz
Maximum input voltage: 90 V AC to 290 V AC, 45 Hz to 65 Hz
Rated input current: 16 A
Power port type: C20
RG-PAH3000I-F (HVDC input):
Rated input voltage: 240 V DC to 380 V DC
Maximum input voltage: 188 V DC to 400 V DC
Rated input current: 14 A
Note: When the switch is equipped with the high-voltage DC power supply, a PDU that supports high-voltage DC power supply must be used. To ensure safety, connect the external power supply to the power cord first and then to the PDU. The switch can only connect to a specific power system (UPS) but not to the DC power grid. The DC voltage tolerance range is from 188 V DC to 400 V DC.
PD2200II-F (DC input):
Maximum input voltage: –38 V DC to –72 V DC
Rated input current: 50 A
Power port type: Rectangular non-metallic locking plug
Rated input voltage: 100 V to 130 VAC, 200 V AC to 240 V AC, 50 Hz/60 Hz
RG-N18018-XH
RG-N18010-XH
Traffic analysis
IPFIX
Layer 2 features
Jumbo frame
IEEE 802.3ad (static link aggregation, LACP, cross-module link aggregation, and M-LAG)
IEEE 802.1Q
QinQ
IPv4 features
Static routing, BGP4, OSPF, IS-IS, and RIP
Policy-based routing
IP fragmentation and reassembly
Manual tunnel and GRE tunnel
IPv6 features
Static routing, BGP4+, OSPFv3, IS-ISv6, and RIPng
VRRPv3
Path MTU discovery
Pingv6, Traceroutev6, Telnetv6, FTPv6, TFTPv6, DNSv6, and ICMPv6
IGMP v1/v2/v3
IGMP Snooping v1/v2
IGMP proxy
PIM-DM, PIM-SM, PIM-SSM, and PIM-SM v6
MLDv1, MLDv2
Static multi cast route
Fast leave
MPLS LDP
SR MPLS (Segment Routing)
SR-TE
Standard, extended (Layer 2 to layer 4), and expert ACL
Global ACL
Ingress and egress ACL
IEEE 802.1p, ToS, and DSCP priority mapping
SP(PQ), DRR, SP(PQ)+DRR, WFQ, SP(PQ)+WFQ, WRR, SP(PQ)+WRR and other queue scheduling mechanisms
Egress/ingress port-based rate limit and CAR
#MPLS QoS
Data center features
#SRv6
VXLAN bridge
VXLAN gateway
BGP-EVPN VXLAN
VXLAN mapping
VXLAN over IPv4
VXLAN over IPv6
M-LAG
RDMA
SDN
OpenFlow 1.3
N+M redundancy for switch fabric modules
Hot swapping of components
BPDU Guard/Loop Guard/Root guard
NSR
FRR
GR for OSPF/IS-IS/BGP
BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/Static routing
Virtualization
Virtual switching unit (VSU)
#MACSec
Network foundation protection protocol (NFPP) and CPU Protection Policy (CPP)
DDoS attack defense, ARP attack defense, and ICMP attack defense
uRPF
RADIUS and TACACS authentication, password security, hierarchical user management, and password protection
Source IP address restriction
Configuring the device not to send unknown multicast packets to the CPU
Suppression of unknown unicast, broadcast, and multicast packets
SSHv2, providing secure encrypted channels for user login
MAC address flapping protection policy
Clear text and MD5 authentication for BGP4, BGP4+, OSPF, OSPFv3, IS-IS, IS-ISv6, and RIPv2 packets
Console/AUX Modem/Telnet/SSHv2 CLI configuration
FTP, TFTP, Xmodem, and SFTP
Netconf
RMON
NTP clock
Fault alarm and auto-recovery
System operation log
Traffic analysis
Zero-Touch provisioning (ZTP)
Telemetry
Supported VXLAN OAM: VXLAN ping VXLAN tracert
Physical ports on all line cards support routing mode and can be configured with IP addresses independently
Fan and power module monitoring
# indicates that the feature is supported only by CE line cards.
Zasoby
Informacje o zamawianiu
RG-N18018-XH
RG- N18018-XH switch, fully equipped with fan modules, without power modules
RG-N18010-XH
RG-N18010-XH chassis, fully equipped with fan modules, without power modules
M18000XH-CM
M18000XH-CM supervisor module, used with Type E switch fabric modules and CE line cards
M18000XH-CM II
M18000XH-CM II supervisor module, used with Type D switch fabric modules and DB line cards
Power Module
RG-PAH3000I-F
3000 W AC power module (supporting AC and 240 V to 380 V HVDC)
PD2200II-F
2200 W DC power module (supporting 54 V DC), applicable to RG-N18018-XH and RG-N18010-XH
Switch Fabric Module
M18018XH-FE-E IV
Type E series switch fabric module of RG-N18018-XH, used with CE line cards
M18018XH-FE-D II
Type D switch fabric module of RG-N18018-XH, used with DB line cards
M18010XH-FE-E II
Type E series switch fabric module of RG-N18010-XH, used with CE line cards
M18010XH-FE-D II
Type D switch fabric module of RG-N18010-XH, used with DB line cards
M18006XH-FE-D I
Type D switch fabric module of RG-N18006-XH, used with DB line cards
Line Cards and Function Modules
M18000XH-36QC-CES
36-port 400G (QSFP-DD) Ethernet optical interface card, CE line card, used together with Type E switch fabric modules
M18000XH-48CQ-CES
48-port 100G QSFP28 Ethernet optical interface card, CE line card, used with Type E series switch fabric modules
M18000XH-36CQ-DB
36-port 100G QSFP28 Ethernet optical interface card, DB line card, used with Type D switch fabric modules
M18000XH-18CQ-DB
18-port 100G QSFP28 Ethernet optical interface card, DB line card, used with Type D switch fabric modules
M18000XH-36QXS-DB
36-port 40G QSFP+ Ethernet optical interface card, DB line card, used with Type D switch fabric modules
M18000XH-48XS-DB
48-port 10G SFP+ Ethernet optical interface card, DB line card, used with Type D switch fabric modules
25G Optical Transceivers
VG-SFP-AOC5M
25G active optical cable (AOC), SFP28 form factor, 5 m (16.40 ft.)
VG-SFP-SR-SM850
25G SR optical transceiver, SFP28 form factor, LC interface, 850 nm, 100 m (328.08 ft.) over multimode fiber (MMF)
25G LR4 optical transceiver, SFP28 form factor, LC interface, 1310 nm, 10 km (32,808.40 ft.) over single-mode fiber (SMF)
40G Optical Transceivers
40G LX4 optical transceiver, QSFP+ form factor, Duplex LC, 150 m (492.13 ft.) over OM3/OM4 MMF, or 2 km (6,561.68 ft.) over SMF
40G LR4 optical transceiver, QSFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
40G iLR4 optical transceiver, QSFP+ form factor, Duplex LC, 2 km (6,561.68 ft.) over SMF
40G SR optical transceiver, QSFP+ form factor, MPO interface, 400 m (1,312.34 ft.) over MMF
40G SR optical transceiver, QSFP+ form factor, MPO interface, 150 m (492.13 ft.) over MMF
100G Optical Transceivers
100GSR optical transceiver, QSFP28 form factor, MPO interface, 850 nm, 100 m (328.08 ft.) over MMF
400G Optical Transceivers
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G-QDD-ZR-SM1550
400G ZR optical transceiver, QSFP-DD form factor, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF
400G-QDD-SR8-MM850
