RG-CS88-08 Przełączniki - 1
RG-CS88-08 Przełączniki - 2
RG-CS88-08 Przełączniki - 3
RG-CS88-08 Przełączniki - 4
RG-CS88-08 Przełączniki - 5
RG-CS88-08 Przełączniki - 6
RG-CS88-08 Przełączniki - 7
RG-CS88-08 Przełączniki - 8
RG-CS88-08 Przełączniki - 9
RG-CS88-08 Przełączniki - 10
RG-CS88-08 Ruijie 10 RU Modular High-Performance Core Switch with Cloud Management
Fit for data center, MAN, campus, and integrated data center and campus scenarios
  • 10 RU compact size, saving space
  • Up to 288 10GE ports on high-density 10GE cards
  • 40GE and 100GE ports, achieving high speed
  • Cloud, Make Your Business Easy
Cloud Managed Modular Core Switch RG-CS88-08
10 RU compact size, saving cabinet space,high-density 1G/10G/40G/100G line cards support up to 288 10GE ports. Only one line card is required to meet networking requirements at the small- or medium-sized network core or medium-sized network aggregation layer.
Dual-Boot Backup
Two flash chips for storing boot software achieve hardware-level boot
redundancy, avoiding switch boot failures due to a flash chip fault.
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
Two axial flow fans for factory delivery support 256-level speed regulation
and precise temperature control, reducing energy consumption and noise.
1+1 Fan Redundancy
Automatic device registration and configuration after device connection
Plug and play without commissioning, fast provisioning
Flexible replacement with no need of reconfiguration
Auto-sensing on ports, facilitating automatic O&M
RG-CS88-08
Interface Specifications
Supervisor module slots
Line card slot
6
Switch fabric module slot
2 (integrated with supervisor modules)
9.6 Tbps
7200 Mpps
CM88-48GT-H, CM88-48SFP-H: 80,000
CM88-8CQ-H, CM88-48XS-H: 96,000
CM88-48GT-H, CM88-48SFP-H: 4,000
CM88-8CQ-H, CM88-48XS-H: 40,000
CM88-48GT-H, CM88-48SFP-H: underlay: 30,000; overlay: 0
CM88-8CQ-H, CM88-48XS-H: underlay: 50,000; overlay: 0 (default and recommended)
CM88-48GT-H, CM88-48SFP-H: 12,000 (default and recommended, shared with IPv6 routes)
CM88-8CQ-H, CM88-48XS-H: 134,000 (default and recommended, shared with IPv6 routes)
CM88-48GT-H, CM88-48SFP-H: 8,000
CM88-8CQ-H, CM88-48XS-H: 16,000
CM88-48GT-H, CM88-48SFP-H: 6,000 (shared with IPv4 routes)
CM88-8CQ-H, CM88-48XS-H: 50,000 (shared with IPv4 routes)
CM88-8CQ-H, CM88-48XS-H: 8,000
 Ingress
CM88-48GT-H, CM88-48SFP-H: 5,000
CM88-8CQ-H, CM88-48XS-H: 4,500
 Egress
CM88-48GT-H, CM88-48SFP-H: 1,000
CM88-8CQ-H, CM88-48XS-H: 2,000
442 mm x 465mm x 441.7 mm (17.40 in. x 18.31 in. x 17.39 in.), 10 RU
Weight (empty chassis and fan modules)
35.6 kg (78.48 lbs)
CPU and Storage
 Supervisor module
CM88-CM: 1.5 GHz quad-core processor
 Service module
 Supervisor module:
CM88-CM: 8 GB
 Service module:
8 GB
SDRAM
 Supervisor module:
CM88-CM: DDR4 4 GB
 Service module:
DDR4 2 GB
Data packet buffer
 Supervisor module:
CM88-CM: DDR4 4GB
 Line Card:
32 MB
Power and Consumption
RG-CS88: < 176 W
 Supervisor module:
CM88-CM: < 50 W
 Service module:
CM88-48GT-H: < 75 W
CM88-48SFP-H: < 95 W
CM88-48XS-H: < 160 W
CM88-8CQ-H: < 130 W
 RG-PA600I-F: 600 W
 RG-PA1600I-F: 90 V AC to 180 V AC
power:12,00 W;180 V AC to 264 V AC
power: 1,600 W
> 200,000 hours
Primary Airflow
 Supervisor module /Service module
Right-to-rear airflow
 System power module
Front-to-rear airflow
0°C to 45°C (32°F to 113°F)
5% to 95% RH (non-condensing)
Operating altitude
–500 m to +5,000 m (–1640.42 ft. to +16404.20 ft.)
Operating noise
55.9 dB at the temperature of 27°C (80.6°F)
73.4 dB at the temperature of 45°C (113°F)
Interface surge protection
Power port: 6 kV
Telecom port: 4 kV (MGMT port)
RG-CS88 Series
Ethernet Switching
Super VLAN, Private VLAN
MPLS IPv6
MPLS 6VPE
GRE tunnel
IP Routing
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
EVPN
IGMP v1/v2/v3
IGMP proxy
IGMP snooping v1/v2/v3
MLDv1 and MLDv2
MLD v1/v2 snooping
Multicast static routing
Standard IP ACLs (hardware ACLs based on IP addresses)
Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port numbers)
Extended MAC ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type)
ACL80 and IPv6 ACL
802.1p
CAR
ICMP
uRPF
VRRP for the super-VLAN
1+1 redundancy for supervisor modules and fan modules, and N+M redundancy for power modules
Hot swapping of components
GR for OSPF/IS-IS/BGP
SPAN, RSPAN, and ERSPAN
NTP
SNTP
Fault alarm and auto-recovery
1.Switch and Supervisor Engine
Select the switch and supervisor engine based on the specific product model.
RG-S7800C switches and supervisor engines
RG-CS88-08
RG-CS88-08 switch, which can accommodate 6 service cards and 2 supervisor engines, and with 2 fans (Purchase at least one RG-PA600I-F/RG-PA1600I-F module.)
CM88-CM
CM88-CM new generation of high-performance engine.
2.Power Modules and Fans
Select the power module based on power supply requirements. Note that at least one power module must be selected.
RG-PA600I-F
Power module (support redundancy, AC, 600W)
RG-PA1600I-F
Power module (support redundancy, AC, 1600W)
M08-FAN
CS88-08 fan: Each M08-FAN tray consists of two fan modules and one fan monitoring card. It blows air to the outside for convection. (This is a default configuration for the switches.)
3.Line Cards
Select the line card based on service requirements. Before ordering a line card, please contact the online customer service personnel for the details about the line card.
Commercial-grade line cards
CM88-48XS-H
48 × 10GE optical ports (SFP+ and LC)
CM88-8CQ-H
8 × 100G Ethernet optical ports (QSFP28 and LC)
CM88-48GT-H
48 × GE electrical ports (RJ45)
CM88-48SFP-H
48 × GE optical ports (SFP+ and LC)
"*" indicates that it will be supported in the future.
