RG-CS86-20XS4VS2QXS-D Przełączniki - 1
RG-CS86-20XS4VS2QXS-D Przełączniki - 2
RG-CS86-20XS4VS2QXS-D Przełączniki - 3
RG-CS86-20XS4VS2QXS-D Przełączniki - 4
RG-CS86-20XS4VS2QXS-D Przełączniki - 5
RG-CS86-20XS4VS2QXS-D Przełączniki - 6
RG-CS86-20XS4VS2QXS-D Przełączniki - 7
RG-CS86-20XS4VS2QXS-D Przełączniki - 8
RG-CS86-20XS4VS2QXS-D Przełączniki - 9
RG-CS86-20XS4VS2QXS-D Przełączniki - 10
RG-CS86-20XS4VS2QXS-D 20-Port 10/2.5GE(SFP+), Layer 3 Ruijie Core/Aggregation Switch with Cloud Management, 4-Port 25/10GE(SFP28), 2-Port 40GE
Suitable for small & medium enterprise core, or large-scale campus network aggregation switch
  • 20 x 10GE SFP+ ports (Compatible with 2.5GE), 4 x 25GE SFP28 ports, and 2 x 40GE QSFP+ ports for uplink
  • Comprehensive QoS policies for flexible network resource allocation and stable services
Cost-effective Full 10GE Layer 3 Core/Aggregation Switch
Suitable for SME network core and large-scale network aggregation, 20 x 10GE ports and 4 x 25GE ports for flexible access, 2 x 40GE ports for high-performance uplink
and Network Connectivity
Optical Port Fault Isolation
multi-plane flow classification and control policy based on MAC flow, IP flow and application flow,
accurate resource allocation for multi-service traffic makes congestion a thing of the past, delivering high-quality networks.
Flexible management modes
Interface Specifications
Fixed Ports
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports. One switch provides a maximum of 32 x 10GE ports, 2 x modular power slots, and 2 x modular fan slots.
Fan module
Dual pluggable modular fans, with front-to-rear ventilation channels
Fan speed regulating and alarm function
2 x replaceable hot-swappable power supply slots
1 x MGMT port, 1 x console port, and 1 x USB port
570 Mpps
760 Gbps
32,768
In: 2,500
Out: 1,000
440 x 330 x 43.6 mm (17.32 in. x 12.99 in. x 1.72 in.), 1 RU
Weight of the empty chassis
4.6 kg (10.14 lbs.)
CPU and Storage
Dual-core CPU, 1.25 GHz
SDRAM
Data packet buffer
4 MB
Power and Consumption
Supported power module type: RG-PA150I-F
AC input:
Rated voltage range: 100–240 V AC; 50/60 Hz
Maximum voltage range: 90–264 V AC; 47/63 Hz
Rated input current: 3 A
HVDC input:
Rated voltage: 240 V DC
Maximum voltage range: 192–288 V AC
Rated current per circuit: 3 A
< 85 W
RG-PA150I-F: 150 W
Rated input voltage
RG-PA150I-F:
AC input:
HVDC input:
Maximum input voltage
RG-PA150I-F:
AC input:
HVDC input:
Maximum voltage range: 192–288 V DC
Primary airflow
Front-to-rear airflow
0°C to 50°C (32°F to 122°F)
5% to 95% RH (non-condensing)
Interface surge protection
Power port: 6 kV/6 kV
Telecom port: 10 kV (MGMT port: 4 kV)
Temperature alarm
Ethernet Switching
Super VLAN, private VLAN
MAC VLAN, port-based VLAN, protocol-based VLAN, IP subnet-based VLAN
IP Routing
IGMP filtering, IGMP immediate leave
RADIUS and TACAS+
Telnet
20 x 1GE/2.5GE/10GE SFP+ ports, 4 x 10GE/25GE SFP28 ports, 2 x 40GE QSFP+ ports, supports up to 32 x 10GE ports, 2 x slots for power supply module, requires at least one RG-PA150I-F power supply module, 2 x slots for fan modules, 2 x pre-installed fans (Purchase at least one RG-PA150I-F module.)
RG-PA150I-F
150 W AC power supply module for RG-CS86-20XS4VS2QXS-D
1000BASE-GT mini GBIC conversion module
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC).
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC)
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC)
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC)
SFP BiDi transceiver-Tx1310/Rx1550, 20 km, LC
SFP BiDi transceiver-Tx1550/Rx1310, 20 km, LC
SFP BiDi transceiver-Tx1310/Rx1550, 40 km, LC
SFP BiDi transceiver-Tx1550/Rx1310, 40 km, LC
SFP 2.5G BiDi transceiver-Tx1310/Rx1550, 3 km,LC
SFP 2.5G BiDi transceiver-Tx1550/Rx1310, 3 km,LC
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 300 m
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 10 km
10G LC fiber module, applicable to SFP+ ports, max cabling distance: 40 km
25G fiber module
25G fiber module
10G SFP+ connector fiber, 1-meter long, including one cable and two connector modules
10G SFP+ connector fiber, 3-meter long, including one cable and two connector modules
10G SFP+ connector fiber, 5-meter long, including one cable and two connector modules
VG-SFP-AOC5M
25G Base SFP+ fiber cable (including modules on both ends), 5-meter long
40G SR fiber module, applicable to QSFP+ ports (OM3/OM4 MPO interface, 8-core, 850 nm wavelength, max cabling distance: 100 m (OM3), 150 m (OM4)
40G-QSFP-LR4 SM1310
40G LR single-mode fiber module, applicable to QSFP+ ports, max cabling distance:10 km (LC, dual-core, 1310 nm wavelength)
40G QSFP+ connector fiber, 5-meter long, including one cable and two connector modules
40G-AOC-10M
40G QSFP+ connector fiber, 10-meter long, including one cable and two connector modules
