Diverse access rates of 10 Gbps/5 Gbps/2.5 Gbps/1 Gbps/100 Mbps and 4 x 25GE SFP28 ports for uplink, enabling flexible networking and high-performance campus networks
48 x 5GE Ethernet ports, 4 x 25GE SFP28 ports, 2 x 40GE QSFP+ ports
RG-CS86-24XMG4XS4VS-UPD24 x 10GE Ethernet ports, 4 x 10GE SFP+ ports, 4 x 25GE SFP28 ports
RG-CS86-24MG4VS-UP24 x 5GE Ethernet ports, 4 x 25GE SFP28 ports
RG-CS86-12XMG4VS-UP12 x 10GE Ethernet ports, 4 x 25GE SFP28 ports
| Hardware Specifications |
RG-CS86-24MG4VS-UP |
RG-CS86-48MG4VS2QXS-UPD |
RG-CS86-24XMG4XS4VS-UPD |
RG-CS86-12XMG4VS-UP |
| Interface Specifications |
| Fixed port |
24 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation |
48 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation |
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 1GE/10GE SFP+ ports 4 x 10GE/25G SFP28 ports |
12 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 10GE/25G SFP28 ports |
| Fan module |
2 fixed fans |
3 modular fans |
3 modular fans |
2 fixed fans |
| Power module |
1 Built-in power module |
2 replaceable hot-swappable power supply slots |
| Fixed management port |
1 x MGMT port 1 x console port 1 x USB port |
| System Specifications |
| Packet forwarding rate |
327 Mpps |
625 Mpps |
565 Mpps |
327 Mpps |
| Switching capacity |
440 Gbps |
840 Gbps |
760Gbps |
440 Gbps |
| MAC address table size |
32,768 |
| ARP table size |
16,000 |
| Number of IPv4 unicast routes |
16,000 |
| Number of IPv4 multicast routes |
4,000 |
| Number of IPv6 unicast routes |
16,000 |
| Number of IPv6 multicast routes |
2,000 |
| Number of ACEs |
Ingress: 2,500 Egress:1,000 |
| Number of VSU members |
2 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
442 × 220 × 43.6 mm (17.40 × 29.92 × 6.89 in.) , 1 RU |
| Weight |
3.65 kg (8.82 lbs) |
6.11 kg (13.47 lbs) |
3.65 kg (8.82 lbs.) |
| CPU and Storage |
| CPU |
ARM processor, 1.25 GHz |
| Flash memory |
1 GB |
1 GB |
1 GB |
1 GB |
| BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
| SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
| Data packet buffer |
4 MB |
4 MB |
4 MB |
4 MB |
| Power Supply and Consumption |
| Maximum power consumption |
Without PoE: < 120 W (Total power consumption of all modules) Full PoE load: < 370 W |
Without PoE: < 240 W (Total power consumption of all modules) Full PoE load: < 1600 W |
Without PoE: < 120 W (Total power consumption of all modules) Full PoE load: < 1650 W |
| Maximum output power |
460W |
RG-PA600I-P-F: 600 W RG-PA1000I-P-F: 1000 W (Input Voltage: 176 V AC to 290 V AC or 190 V DC to 290 V DC) 930 W (Input Voltage: 90 V AC to 176 V AC, 176 V AC not included) |
460W |
| Rated Input Voltage |
Built-in power module Rated voltage range: 100 V AC to 240 V AC |
Available model: RG-PA600I-P-F Rated voltage range: 100 V AC to 240 V AC Available model: RG-PA1000I-P-F Rated voltage range: 100 V AC to 240 V AC |
| Maximum input voltage |
Built-in power module Maximum voltage range: 90 V AC to 264 V AC |
Available model: RG-PA600I-P-F Maximum voltage range: 90 V AC to 264 V AC Available model: RG-PA1000I-P-F Maximum voltage range: 90 V AC to 264 V AC |
| PoE-capable Port |
Ports 1 to 24 support PoE/PoE+ and HPoE power supply |
Ports 1 to 48 support PoE/PoE+ power supply |
Ports 1 to 12 support PoE/PoE+ and HPoE power supply Maximum output power of a HPoE-capable port: 90 W |
| MTBF |
22.18 years |
27.02 years |
22.18 years |
22.18 years |
| Primary airflow |
Front/Left-to-rear airflow |
| Operating Temperature |
0°C to 45°C (32°F to 113°F) |
| Storage Temperature |
–40°C to +70°C (–40°F to +158°F) |
| Operating Humidity |
10% RH to 90% RH (non-condensing) |
| Storage Humidity |
5% RH to 95% RH (non-condensing) |
| Surge Protection |
6 kV |
6 kV |
6 kV |
6 kV |
| Temperature Monitoring |
Temperature alarm |
Temperature alarm |
Temperature alarm |
Temperature alarm |
| Software Specifications |
| Ethernet switching |
Jumbo frame (maximum length: 9216 bytes) |
| IEEE 802.1Q (supporting 4K VLANs) |
| Voice VLAN |
| Super VLAN, Private VLAN |
| MAC VLAN, Port based VLAN, Protocol based VLAN, IP-Subnet based VLAN |
| GVRP |
| Basic QinQ Flexible QinQ |
| STP, RSTP, and MSTP |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| LACP (IEEE 802.3ad) |
| IP service |
ARP |
| DHCP snooping |
| DNS |
| DHCPv6 client and DHCPv6 relay |
| DHCPv6 snooping |
| IP Routing |
Static routing |
| RIP and RIPng |
| OSPFv2, OSPFv3, IS-ISv4, ISv4, and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4 and IPv6 PBR |
| ECMP |
| Multicast |
| IGMP v1/v2/v3 snooping |
| MSDP |
| MLD v1/v2 |
| MLD snooping v1/v2 |
| PIM-SMv6 and PIM-SSM v6 |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs Time-based ACLs Expert-level ACLs ACL80 IPv6 ACL |
| Port traffic rate limiting |
| 802.1p/DSCP/ToS traffic classification Eight priority queues per port |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Port-based and MAC-based 802.1x authentication |
| Web authentication |
| HTTPS |
| SSHv1, SSHv2 |
| Global IP-MAC binding |
| IP source guard |
| SAVI |
| CPP and NFPP |
| Strict and loose RPF uRPF ignoring default routes |
| Reliability |
REUP, RLDP, DLDP |
| BFD |
| GR for RIP, OSPF, BGP |
| 1+1 power redundancy |
| Hot swapping of power and fan modules |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN, and ERSPAN |
| sFLOW |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP (TR-069) standard protocol |
| gRPC |
| Cloud and SON |
| PoE |
IEEE 802.3af, 802.3at and 802.3bt Uninterruptible power supply upon hot start Port priority |
Follow the steps to order a RG-CS86 multi-GE switch:
| Model |
Description |
24 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation fixed AC power supply and fan |
48 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 + 2 x 40GE QSFP+ ports, support PoE/PoE+/PoE++(25-48 ports only support PoE/PoE+) 2 modular power supply slots (at least one RG-PA600I-P-F/ RG-PA1000I-P-F power module needed,no power module in default),3 modular fan slots (3 fan modules are equipped by default) |
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports , 4 x 10GE/25GE SFP28 ports,support PoE/PoE+/PoE++ 2 modular power supply slots (at least one RG-PA600I-P-F or RG-PA1000I-P-F power module needed,no power module in default),3 modular fan slots (3 fan modules are equipped by default) |
12 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation, 4 x 10GE/25GE SFP28 ports,support PoE/PoE+/PoE++ fixed AC power supply and fan |
| RG-PA600I-P-F |
600 W AC power module |
| RG-PA1000I-P-F |
1000 W AC power module |
| Model |
Description |
| Mini-GBIC-GT |
1000BASE-GT mini GBIC module |
| MINI-GBIC-SX-MM850 |
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC). |
| MINI-GBIC-LX-SM1310 |
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC) |
| MINI-GBIC-LH40-SM1310 |
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC) |
| MINI-GBIC-ZX80-SM1550 |
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC) |
| GE-SFP-LX20-SM1310-BIDI |
SFP BIDI Transceiver-TX1310/RX1550, 20 km, LC |
| GE-SFP-LX20-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 20 km, LC |
| GE-SFP-LH40-SM1310-BIDI |
SFP BIDI Transceiver-TX1310/RX1550, 40 km, LC |
| GE-SFP-LH40-SM1550-BIDI |
SFP BIDI Transceiver-TX1550/RX1310, 40 km, LC |
| Model |
Description |
| XG-SFP-SR-MM850 |
10GE SR, SFP+ transceiver, LC, 850-nm wavelength, applicable to SFP+ port |
| XG-SFP-LR-SM1310 |
10GE LR, SFP+ transceiver, LC, 1310-nm wavelength, 10 km over SMF, applicable to SFP+ ports |
| XG-SFP-ER-SM1550 |
10GE ER, SFP+ transceiver, LC, 1550-nm wavelength, 40 km over SMF, applicable to SFP+ ports |
| XG-SFP-AOC1M |
10GE SFP+ active optical cable, 1 m, including one cable and two interface modules |
| XG-SFP-AOC3M |
10GE SFP+ active optical cable, 3 m, including one cable and two interface modules |
| XG-SFP-AOC5M |
10GE SFP+ active optical cable, 5 m, including one cable and two interface modules |
| Model |
Description |
| VG-SFP-SR-MM850 |
25GE SR, SFP28, 850-nm wavelength, 100 m over MMF |
| VG-SFP-LR-SM1310 |
25GE LR, SFP28, 1310-nm wavelength, 10 km over SMF |
| VG-SFP-AOC5M |
25GE SFP+ active optical cable, 5 m, including two modules |
| Model |
Description |
| 40G-QSFP-SR-MM850 |
40GE SR, QSFP+ transceiver, applicable to QSFP+ ports |
| 40G-QSFP-LR4 SM1310 |
40GE LR4, QSFP+ transceiver, LC, 1310-nm wavelength, 2-core, 10 km over SMF, applicable to QSFP+ ports |
| 40G-AOC-5M |
40GE QSFP+ active optical cable, 5 m, including one cable and two interface modules |
| 40G-AOC-10M |
40GE QSFP+ active optical cable, 10 m, including one cable and two interface modules |
