48-Port GE Electrical Ports, 4 × 10G Optical Ports, PoE/PoE+
RG-CS85-48SFP4XS-D48-Port GE Optical Ports, 4 × 10G Optical Ports
RG-CS85-48GT4XS-D48-Port GE Electrical Ports,4 × 10G Optical Ports
RG-CS85-24SFP/8GT8XS-D24-Port GE Optical Ports (with Eight Combo Ports), 8 × 10G Optical Ports
RG-CS85-24GT8XS-D24 x GE Electrical Ports, 8 x 10GE Optical Ports
| Hardware Specifications |
RG-CS85-24GT8XS-D |
RG-CS85-24SFP/8GT8XS-D |
RG-CS85-48GT4XS-D |
RG-CS85-48GT4XS-HPD |
RG-CS85-48SFP4XS-D |
| Interface Specifications |
| Fixed port |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports |
24 x 1000 Mbps SFP ports (ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, PoE/PoE+ supported, 4 x 1GE/10GE SFP+ ports |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports |
| Fan module |
3 fixed fans |
3 fixed fans |
3 fixed fans |
2 modular fans |
3 modular fans |
| Power module |
2 replaceable hot-swappable power supply slots |
| Fixed management port |
1 x console, 1 x MGMT, 1 x USB3.0 |
| Expansion slot |
One expansion slot |
| System Specifications |
| Packet forwarding rate |
512 Mpps |
512 Mpps |
488 Mpps |
488 Mpps |
488 Mpps |
| Switching capacity |
688 Gbps |
688 Gbps |
656 Gbps |
656 Gbps |
656 Gbps |
| MAC address table size |
64,000 |
64,000 |
64,000 |
64,000 |
64,000 |
| ARP table size |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
| Number of IPv4 unicast routes |
24,000 |
24,000 |
24,000 |
24,000 |
24,000 |
| Number of IPv4 multicast routes |
4,000 |
4,000 |
4,000 |
4,000 |
4,000 |
| Number of IPv6 unicast routes |
14,000 |
14,000 |
14,000 |
14,000 |
14,000 |
| Number of IPv6 multicast routes |
2,000 |
2,000 |
2,000 |
2,000 |
2,000 |
| Number of ACEs |
Ingress: 7,000 Egress:1,500 |
| Number of VSU members |
4 |
4 |
4 |
4 |
4 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
440 x 340 x 44 mm (17.32 x 13.39 x 1.73 in), 1 RU |
442 x 420 x 43.6 mm (17.40 x 16.54 x 1.72 in), 1 RU |
| Weight |
4.4 kg (9.70 lbs) |
4.3 kg (9.48 lbs) |
4.5 kg (9.92 lbs) |
5.5 kg (12.12 lbs) |
5.3 kg (11.68 lbs) |
| CPU and Storage |
| CPU |
Dual-core CPU, 1.2 GHz |
| Flash memory |
4 GB |
4 GB |
4 GB |
4 GB |
4 GB |
| BootROM |
16 MB |
16 MB |
16 MB |
16 MB |
16 MB |
| SDRAM |
1 GB |
1 GB |
1 GB |
1 GB |
1 GB |
| Data packet buffer |
4 MB |
| Power and Consumption |
| Maximum power consumption |
<60 W (excluding expansion modules) |
<77 W (excluding expansion modules) |
<70 W (excluding expansion modules) |
<110 W (non-PoE) <1,590 W (PoE full load) |
<150 W |
| Maximum output power |
RG-PA150IB-F: 150 W |
RG-PA600I-P-F: 600 W RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000 W 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
| Rated input voltage |
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V |
AC: 200 V to 240 V
DC: -48 V to -60 V |
AC: 100 V to 240 V DC: -48 V to -60 V |
| Maximum input voltage |
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V |
AC: 176 V to 264 V
DC: -38 V to -75 V |
AC: 90 V to 264 V
DC: -36 V to -75 V |
| MTBF |
≥ 1,051,000 hours |
≥ 823,000 hours |
≥ 963,000 hours |
≥ 832,000 hours |
≥ 788,000 hours |
| Primary Airflow |
Left-to-right and front-to-right airflow |
Front-to-rear airflow |
| Operating temperature |
0°C to 45°C (32°F to 113°F) |
| Storage temperature |
-40°C to +70°C (-40°F to +158°F) |
| Operating humidity |
10% to 90% RH (non-condensing) |
| Storage humidity |
5% to 95% RH (non-condensing) |
| Operating noise |
45°C: 56.2 dB |
45°C: 57.1 dB |
45°C: 57.9 dB |
27°C: 50 dB 45°C: 65 dB |
27°C: 53 dB 45°C: 68 dB |
| Interface surge protection |
Power port: 6 kV/6 kV Telecom port: 10 kV (MGMT port: 4 kV) |
| RG-CS85 Series |
| Feature |
Description |
| Ethernet switching |
| IEEE 802.1Q (supporting 4K VLANs) |
| Voice VLAN |
| Super VLAN, Private VLAN |
| MAC VLAN, Port based VLAN, Protocol based VLAN, IP-Subnet based VLAN |
| GVRP |
| Basic QinQ Flexible QinQ |
| STP, RSTP, and MSTP |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| LACP (IEEE 802.3ad) |
| IP service |
ARP |
| DHCP snooping |
| DNS |
| DHCPv6 client and DHCPv6 relay |
| DHCPv6 snooping |
| IP routing |
Static routing |
| RIP and RIPng |
| OSPFv2, OSPFv3, IS-ISv4, ISv4, and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4 and IPv6 VRF |
| IPv4 and IPv6 PBR |
| Multicast |
| IGMP v1/v2/v3 snooping |
| MSDP |
| MLD v1/v2 |
| MLD snooping v1/v2 |
| PIM-SMv6 and PIM-SSM v6 |
| MPLS |
MPLS L3VPN |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs Time-based ACLs Expert-level ACLs ACL80 IPv6 ACL |
| ACL redirection |
| Port traffic rate limiting |
| 802.1p/DSCP/ToS traffic classification Eight priority queues per port |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Port-based and MAC-based 802.1x authentication |
| Web authentication |
| HTTPS |
| SSHv1, SSHv2 |
| Global IP-MAC binding |
| IP source guard |
| SAVI |
| CPP and NFPP |
| Strict and loose RPF uRPF ignoring default routes |
| Reliability |
REUP, RLDP, DLDP |
| BFD |
| Hot swapping of power modules and cables |
| 3-level fan speed adjustment Fan fault alarm |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN, and ERSPAN |
| sFLOW |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP (TR-069) standard protocol |
| gRPC |
| Cloud and SON |
| PoE |
IEEE 802.3af and 802.3at Uninterruptible power supply upon hot start Port priority |
| Model |
Description |
| RG-CS85-24GT8XS-D |
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
| RG-CS85-48GT4XS-D |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.) |
| CM85-4XS2CQ |
Expansion module, 4 x 10GE SFP+ ports and 2 x 100GE QSFP28 ports |
| RG-PA150IB-F |
150 W AC power supply module |
| RG-PA600I-P-F |
600 W PoE AC power supply module |
| RG-PA1000I-P-F |
1000 W PoE AC power supply module |
| Mini-GBIC-GT |
1000BASE-GT mini GBIC module |
| MINI-GBIC-SX-MM850 |
Single-port 1000BASE-SX mini GBIC module (LC interface) |
| MINI-GBIC-LX-SM1310 |
Single-port 1000BASE-LX mini GBIC module (LC interface) |
| MINI-GBIC-LH40-SM1310 |
Single-port 1000BASE-LH mini GBIC module (LC interface), supporting a transmission distance of 40 km (24.85 miles) |
| MINI-GBIC-ZX50-SM1550 |
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 50 km (24.85 miles) |
| MINI-GBIC-ZX80-SM1550 |
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 80 km (24.85 miles) |
| MINI-GBIC-ZX100-SM1550 |
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km (62.14 miles) |
| XG-SFP-SR-MM850 |
10GE LC module (62.5/125μm: 33 m (108.27 ft); 50/125μm: 66 m (216.54 ft); transmit for 300 m (984.25 ft) when modal bandwidth is 2000Mhz *km), applicable to SFP+ ports |
| XG-SFP-LR-SM1310 |
10GE LC interface module (1310 nm), 10 km (6.21 miles), applicable to SFP+ ports |
| XG-SFP-ER-SM1550 |
10GE LC interface module (1550 nm), 40 km (24.85 miles), applicable to SFP+ ports |
| XG-SFP-AOC1M |
10GE SFP+ fiber-optic cable, 1 m (3.28 ft), including one cable and two interface modules |
| XG-SFP-AOC3M |
10GE SFP+ fiber-optic cable, 3 m (3.28 ft), including one cable and two interface modules |
| XG-SFP-AOC5M |
10GE SFP+ fiber-optic cable, 5 m (3.28 ft), including one cable and two interface modules |
