24 x GE Electrical Ports, 4 x 10GE Optical Ports, PoE+
RG-CS83-48GT4XS-PD48 x GE Electrical Ports, 4 x 10GE Optical Ports, PoE+
| Hardware Specifications |
RG-CS83-24GT4XS-PD |
RG-CS83-48GT4XS-PD |
| Interface Specifications |
| Fixed ports |
24 x 10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports PoE standards: IEEE 802.3af and 802.3at |
48 x 10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports PoE standards: IEEE 802.3af and 802.3at |
| Fans modules |
1 x fixed fan module |
| Power modules |
2 replaceable hot-swappable power supply slots |
| Fixed management ports |
1 x MGMT port, 1 x console port, and 1 x USB port |
| System Specifications |
| Packet forwarding rate |
96 Mpps |
132 Mpps |
| Switching capacity |
128 Gbps |
176 Gbps |
| MAC address table size |
32,000 |
| ARP table size |
4,000 |
| Number of IPv4 unicast routes |
8,000 |
| Number of IPv4 multicast routes |
2,500 |
| Number of IPv6 unicast routes |
4,000 |
| Number of IPv6 multicast routes |
1,200 |
| Number of ACEs |
Ingress: 3,500 Egress:1,500 |
| Number of VSU members |
4 |
| VLAN translation |
4,094 |
| Dimensions and Weight |
| Dimensions (W x D x H) |
442 x 420 x 43.6 mm (17.40 x 16.54 x 1.72 in), 1 RU |
| Weight (empty chassis and fan modules) |
4.3 kg (9.48 lbs) |
4.6 kg (10.14 lbs) |
| CPU and Storage |
| CPU |
Dual cores, with the clock speed of 1.2 GHz |
| Flash memory |
2 GB |
| BootROM |
16 MB |
| SDRAM |
1 GB |
| Data packet buffer |
3 MB |
| Power and Consumption |
| Maximum power consumption |
< 65 W (non-PoE) < 810 W (PoE full load) |
< 75 W (non-PoE) < 1570 W (PoE full load) |
| Maximum output power |
RG-PA600I-P-F: 600 W (PoE: 370 W) RG-PA1000I-P-F: 176 V AC to 290 V AC, 1000W 90 V AC to 176 V AC, 930 W (PoE: 740 W) |
| Rated input voltage |
RG-PA600I-P-F: AC: 100 V AC to 240 V AC, 50/60 Hz HVDC: 240 V DC RG-PA1000I-P-F: AC: 100 V AC to 240 V AC, 50/60 Hz HVDC: 240 V DC |
| Maximum input voltage |
RG-PA600I-P-F: AC: 90 V AC to 264 V AC, 47/63 Hz HVDC: 192 V DC to 288 V DC RG-PA1000I-P-F: AC: 90 V AC to 264 V AC, 47/63 Hz HVDC: 192 V DC to 288 V DC |
| MTBF |
≥ 356,000 hours (dual power modules) ≥ 208,000 hours (single power module) |
≥ 315,000 hours (dual power modules) ≥ 193,000 hours (single power module) |
| Primary Airflow |
Left-to-right and front-to-right airflow |
| Operating temperature |
0°C to 45°C (32°F to 113°F) |
| Storage temperature |
-40°C to +70°C (-40°F to +158°F) |
| Operating humidity |
10% to 90% RH (non-condensing) |
| Storage humidity |
5% to 95% RH (non-condensing) |
| Operating noise |
27°C: 51.6 dB 45°C: 57.4 dB |
27°C: 51.6 dB 45°C: 58.3 dB |
| Interface surge protection |
Power port: 6 kV/6 kV Telecom port: 10 kV (MGMT port: 4 kV) |
| RG-CS83-PD Series |
| Feature |
Description |
| Ethernet switching |
Jumbo frame (maximum length: 9216 bytes) |
| IEEE 802.1Q (4K VLANs) |
| Voice VLAN |
| Super VLAN and private VLAN |
| MAC VLAN, port-based VLAN, protocol-based VLAN, and IP-subnet based VLAN |
| GVRP |
| Basic QinQ Selective QinQ |
| STP, RSTP, and MSTP |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| LACP (IEEE 802.3ad) |
| IP service |
ARP |
| DHCP snooping |
| DNS |
| DHCPv6 client and DHCPv6 relay |
| DHCPv6 snooping |
| IP routing |
Static routing |
| RIP, RIPng |
| OSPFv2, OSPFv3, IS-ISv4, ISv4, and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4 and IPv6 VRF |
| IPv4 and IPv6 PBR |
| Multicast |
| IGMP v1/v2/v3 snooping |
| MSDP |
| MLD v1/v2 |
| MLD snooping v1/v2 |
| PIM-SMv6, PIM-SSM v6 |
| ACL and QoS |
Standard IP ACLs Extended IP ACLs Extended MAC ACLs ACL80 IPv6 ACL |
| ACL redirection |
| Port traffic identification |
| Port traffic rate limiting |
| Traffic policing: CAR |
| Rate limiting in each queue |
| Security |
Multiple AAA modes |
| RADIUS and TACAS+ |
| Port-based and MAC-based 802.1x authentication |
| Web authentication |
| Allowlist |
| HTTPS |
| SSHv1, SSHv2 |
| Global IP-MAC binding |
| ICMP |
| IP Source Guard |
| SAVI |
| Gateway ARP anti-spoofing |
| CPP(CPU Protection Policy) |
| NFPP( Network Foundation Protection Policy) |
| Strict and loose RPF uRPF ignoring default routes |
| Reliability |
REUP, RLDP, DLDP |
| BFD |
| Hot swapping of power modules and cables |
| 3-level fan speed adjustment Fan fault alarm |
| Device virtualization |
| NMS and maintenance |
SPAN, RSPAN, and ERSPAN |
| sFlow |
| NTP and SNTP |
| FTP and TFTP |
| SNMP v1/v2/v3 |
| RMON (1, 2, 3, 9) |
| NETCONF |
| CWMP (TR-069) standard protocol |
| gRPC |
| Cloud and SON |
| PoE |
IEEE 802.3af and 802.3at Uninterruptible power supply upon hot start Port priority |
| Model |
Description |
24 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 740 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE remote power supply and the maximum PoE output power of 1480 W. (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.) |
| RG-PA600I-P-F |
600 W AC power module, PoE power module |
| RG-PA1000I-P-F |
1000 W AC power module, PoE power module |
| Mini-GBIC-GT |
1000BASE-GT mini GBIC module |
| Mini-GBIC-SX-MM850 |
Single-port 1000BASE-SX mini GBIC module (LC interface) |
| Mini-GBIC-LX-SM1310 |
Single-port 1000BASE-LX mini GBIC module (LC interface) |
| Mini-GBIC-LH40-SM1310 |
Single-port 1000BASE-LH mini GBIC module (LC interface), supporting a transmission distance of 40 km |
| Mini-GBIC-ZX100-SM1550 |
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km |
| XG-SFP-SR-MM850 |
10G LC interface module (62.5/125 μm: 33 m; 50/125 μm: 66 m; 300-meter transmission at modal bandwidth of 2000 MHz•km), applicable to SFP+ ports |
| XG-SFP-LR-SM1310 |
10G LC interface module (1310 nm), 10 km, applicable to SFP+ ports |
| XG-SFP-ER-SM1550 |
10G LC interface module (1550 nm), 40 km, applicable to SFP+ ports |
