RG-CS83-12GT4XS-P Przełączniki - 1
RG-CS83-12GT4XS-P Przełączniki - 2
RG-CS83-12GT4XS-P Przełączniki - 3
RG-CS83-12GT4XS-P Przełączniki - 4
RG-CS83-12GT4XS-P Przełączniki - 5
RG-CS83-12GT4XS-P Przełączniki - 6
RG-CS83-12GT4XS-P Przełączniki - 7
RG-CS83-12GT4XS-P Przełączniki - 8
RG-CS83-12GT4XS-P Przełączniki - 9
RG-CS83-12GT4XS-P Przełączniki - 10
RG-CS83-12GT4XS-P,12-Port GE Electrical Layer 3 Managed Access Switch with PoE+
RG-CS83-12GT4XS-P
12 x 1000 Mbps electrical ports and four 10G optical ports for flexible networking PoE+ supported, providing power to powered devices on security hybrid systems andwireless coverage systems
Flexible installation
Silence
Carrier-class Reliability
10 kV Surge Protection
Make Your Business Easy
Flexible Management Modes
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
Interface Specifications
Fixed ports
12 x 100M/1000M  BASE-T ports
support PoE+
24 x 100M/1000M BASE-T ports
48 x 100M/1000M BASE-T ports
support PoE+
support PoE+
No fan
1 x fixed power module
1 x console, and 1 x USB 2.0 port
78 Mpps
96 Mpps
132 Mpps
96 Mpps
132 Mpps
104 Gbps
128 Gbps
176 Gbps
128 Gbps
176 Gbps
6,000
750
Ingress: 1,750
Egress: 800
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3.75 kg (8.27 lbs)
CPU and Storage
1.0 GHz dual-core CPU
512 MB
512 MB
512 MB
512 MB
512 MB
SDRAM
Data packet buffer
Power and Consumption
< 35 W (non-PoE)
< 405 W (PoE full load)
< 25 W
< 40 W
< 35 W (non-PoE)
< 52 W (non-PoE)
< 460 W (PoE full load)
409 W
Maximum  PoE output :370W
409 W
460 W
Maximum  PoE output :405W
Rated input voltage
100 V AC to 240 V AC
Maximum input voltage
90 V AC to 264 V AC, 50 Hz to 60 Hz
24.14 years
23.74 years
23.85 years
23.94 years
22.86 years
Primary airflow
0°C to 45°C (32°F to 113°F)
5% to 95% RH (non-condensing)
Operating noise
27℃: < 35 dB
< 20 dB
27℃: < 32 dB
27℃: < 35 dB
27℃: < 35 dB
Interface surge protection
Power port: 6 kV(common mode)/8 kV (differential mode)
Communication port: 10 kV
Power port: 6 kV(common mode)/6 kV (differential mode)
RG-CS83 Series
IGMP v1/v2 snooping
RADIUS and TACAS+
SPAN, RSPAN
Warm start
Interface priority
RG-CS83-12GT4XS-P
12 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module
RG-CS83-24GT4XS
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module
RG-CS83-48GT4XS
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, and built-in power module
RG-CS83-24GT4XS-P
24 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 370 W PoE output, and built-in power module
RG-CS83-48GT4XS-P
48 x 10M/100M/1000M electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, PoE power supply, a maximum of 405 W PoE output, and built-in power module
1000BASE-GT mini GBIC module
Single-port 1000BASE-SX mini GBIC module (LC connector)
Single-port 1000BASE-LX mini GBIC module (LC connector)
Single-port 1000BASE-LH mini GBIC module (LC connector), supporting a transmission distance of 40 km (24.85 miles)
MINI-GBIC-ZX50-SM1550
Single-port 1000BASE-ZX mini GBIC module (LC connector), supporting a transmission distance of 50 km (24.85 miles)
Single-port 1000BASE-ZX mini GBIC module (LC connector), supporting a transmission distance of 80 km (24.85 miles)
MINI-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km (62.14 miles)
10GE LC module (62.5/125 μm: 33 m (108.27 ft.); 50/125 μm: 66 m (216.54 ft.); transmit for 300 m (984.25 ft.) when modal bandwidth is 2000 MHz * km), applicable to SFP+ ports
10GE SFP+ fiber-optic cable, 1 m (3.28 ft.), including one cable and two interface modules
10GE SFP+ fiber-optic cable, 3 m (3.28 ft.), including one cable and two interface modules
10GE SFP+ fiber-optic cable, 5 m (3.28 ft.), including one cable and two interface modules
