RG-SAP685-SP Wireless - 1
RG-SAP685-SP Wireless - 2
RG-SAP685-SP Wireless - 3
RG-SAP685-SP Wireless - 4
RG-SAP685-SP Wireless - 5
RG-SAP685-SP Wireless - 6
RG-SAP685-SP Wireless - 7
RG-SAP685-SP Wireless - 8
RG-SAP685-SP Wireless - 9
RG-SAP685-SP Wireless - 10
RG-SAP685-SP Wireless - 11
RG-SAP685-SP, Wi-Fi 6 Dual-Radio 2.976 Gbps Cost-Effective Outdoor Access Point with Directional Antennas
  • Upgraded to Wi-Fi 6, cost-effective high-speed at 2.976 Gbps
  • Built-in directional antennas, focused coverage and strong signal
  • Industrial-grade product design with IP68 rating
WaaS Series Outdoor Access Point
RG-SAP685-SP
Built-in
160 MHz
Channel Width
Max Data Rate
2.976 Gbps
IP68
Rating
2.5 Gbps SFP Port and 1 Gbps Electrical Port,
Flexible Networking
2.5 Gbps SFP Port
Designed for all-optical networks, enabling high-bandwidth Wi-Fi coverage of over 1 km in outdoor scenarios.
Used for wired connection, meeting networking demands and maximizing the return on investment (ROI).
Built-in High-Power Directional Antennas,
Strong and Focused Signals
Built-in directional antennas with a transmit power of 28 dBm concentrate strong signal beams, meeting the wireless requirements for Internet access in pedestrian streets and long-distance security surveillance backhaul.
Industrial-Grade Product Design, Stable Running in Harsh Outdoor Environments
IP68 Rating
Lightning Protection
Wide Temperature Range
IP68 rating protection against dust and water, preventing liquid and sand intrusion.
160 MHz Channel Width, Up to 2.976 Gbps Data Rate
Next-generation AX3000 chip supports 160 MHz channel width in the 5 GHz frequency band,
doubling the data throughput compared with 80 MHz channel width.
160MHz 2.976 Gbps
WIS Cloud enables network-wide configuration and optimization, eliminating the need for on-site operations.
Network issue warnings allows wireless networks to be monitored anytime and anywhere.
Go to WIS Cloud >>
Cloud O&M
24/7 Network Optimization
Real-Time Warning
Fault Locating
RG-SAP685-SP
Four spatial streams
Channels:
Two spatial streams
Channels:
Channels:
● 2.4 GHz: two built-in directional antennas, with peak antenna gain of 9 dBi.
● 5 GHz: two built-in directional antennas, with peak antenna gain of 9 dBi.
● One integrated vertically polarized omnidirectional antenna, with peak antenna gain of 4.5 dBi.
1 x 2.5GE SFP port, compatibility with 1GE module
1 x 10/100/1000BASE-T port
1 x Bluetooth 5.0
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
● Whether bridging is enabled
Main unit: 1.5 kg (3.31 lbs)
Shipping: 2.92 kg (6.44 lbs)
● DC power: 12.95 W
● 802.3at (PoE+): 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6.0 W
512 MB DRAM, 128 MB flash
2.4GHz
● Maximum transmit power: 28 dBm (631mW)
5GHz
RG-SAP685-SP
25 dBm
–92 dBm
25 dBm
25 dBm
–84 dBm
25 dBm
–78 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–63 dBm
25 dBm
–84dBm
25 dBm
–51 dBm
25 dBm
–84 dBm
–74 dBm
–72 dBm
–67 dBm
25 dBm
–84 dBm
–66 dBm
25 dBm
–81 dBm
–63 dBm
25 dBm
–84 dBm
19 dBm
–61 dBm
25 dBm
–81 dBm
19 dBm
–56 dBm
25 dBm
–78 dBm
19 dBm
25 dBm
–84 dBm
25 dBm
–81 dBm
–51 dBm
25 dBm
–78 dBm
–48 dBm
5 GHz, 802.11ax (HE160)
25 dBm
–73 dBm
–43 dBm
Note Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see WLAN Country or Region Codes and Channel Compliance.
RG-SAP685-SP
RGOS11.9(6)W2B4 or later
128
Maximum. number of BSSIDs
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
PSK and web authentication
ACL REMARK
MAC address table size: 1,024
Jumbo frame length: 1518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-SAP685-SP
Big data capabilities
RG-SAP685-SP
EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, EN 301 489-1, EN 301 489-3, EN 301 489-17, EN 300 328, EN 301 893, EN 300 440, FCC Part 15, EN IEC 62311, IEC 62368-1, EN 62368-1, and IEC 60950-22
RG-SAP685-SP
●     Radio 2: 5 GHz: two spatial streams, 2x2 MU-MIMO, peak data rate of 2.402 Gbps
●     The DC power supply needs to be purchased separately, and the output voltage/current must be 48 V/0.35 A.
