RG-AP840-I(V2) Wireless - 1
RG-AP840-I(V2) Wireless - 2
RG-AP840-I(V2) Wireless - 3
RG-AP840-I(V2) Wireless - 4
RG-AP840-I(V2) Wireless - 5
RG-AP840-I(V2) Wireless - 6
RG-AP840-I(V2) Wireless - 7
RG-AP840-I(V2) Wireless - 8
RG-AP840-I(V2) Wireless - 9
RG-AP840-I(V2) Wireless - 10
Ruijie Wi-Fi 6 Series Enhanced Indoor Settled AP
RG-AP840-I(V2)
5G Optical Port
PoE/DC Power Supply
Bluetooth 5.1
Ceiling/Wall Mounting
WIS-based Management
5G Optical Port and 5G Electrical Port for Flexible Networking
One 5G optical port supports an all-optical network. With Ruijie All-Optical i-Share+ Solution, this port helps achieve fiber access in rooms.
Upgraded to Wi-Fi 6
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
160 MHz and 6 Spatial Streams
Unified Cloud Management
Go to WIS ->
Cloud O&M
24h Network Optimization
Real-Time Warning
Fault Locating
RG-AP840-I(V2)
Six spatial streams
● Radio 2 – 5 GHz: 4x4 MIMO, four spatial streams
Channels:
● Radio 2 – 5 GHz: 6.5 Mbps to 600 Mbps (MCS0 to MCS31)
Four spatial streams
Channels:
Combined peak data rate: 3.467 Gbps
● Radio 2 – 5 GHz: 6.5 Mbps to 3.467 Gbps (MCS0 to MCS9)
Six spatial streams
● Radio 2 – 5 GHz: 4x4 uplink/downlink MU-MIMO, four spatial streams
Channels:
● Radio 2 – 5 GHz: 8.6 Mbps to 4.804 Gbps (MCS0 to MCS11)
● 2.4 GHz: two built-in omnidirectional antennas, with peak antenna gain of 5.9 dBi.
● 5 GHz: four built-in omnidirectional antennas, with peak antenna gain of 6.2 dBi.
1 x 10/100/1000BASE-T RJ45 port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Shipping: 284 mm x 262 mm x 124 mm (11.18 in. x 10.31 in. x 4.88 in.)
Main unit: 1.0 kg (2.20 lbs)
Shipping: 1.25 kg (2.76 lbs)
● DC power: 40 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● 802.3bt (PoE++): 40 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 for PoE supply, and USB port enabled
● 802.3at (PoE+): 22 W, 2.4 GHz radio 2x2, 5 GHz radio 4x4, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● 802.3af (PoE): 12.95 W, 2.4 GHz radio 1x1, 5 GHz radio 1x1, LAN 2 and USB port that fail to provide power for external devices (PoE out disabled of LAN 2 and USB port disabled)
● Idle mode: 10.3 W
External power supply
512 MB DRAM, 256 MB flash
● Maximum transmit power: 27 dBm (500 mW)
● Maximum transmit power: 30 dBm (1000 mW)
RG-AP840-I(V2)
24 dBm
–96 dBm
24 dBm
–95 dBm
–93 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–62 dBm
24 dBm
–88 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–68 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–63 dBm
24 dBm
24 dBm
–90 dBm
24 dBm
–86 dBm
–56 dBm
–83 dBm
5 GHz, 802.11ax (HE160)
–81 dBm
–51 dBm
Basic Functions
RG-AP840-I(V2)
RGOS11.9(6)W2B7 or later
160
Maximum number of WLAN IDs
Rate set settings
MU and TAG device locating
Application management
Dynamic Policy
CoA/DM
MAC address table size: 2,048
Jumbo frame length: 1,518
IEEE802.1p and IEEE802.1Q
Maximum number of SVIs: 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
NTP server and NTP client
RG-AP840-I(V2)
Big data capabilities
RG-AP840-I(V2)
EN 55032,EN 55035,EN 61000-3-3,EN IEC 61000-3-2,EN 301 489-1,EN 301 489-3,EN 301 489-17,EN 300 328,EN 301 893,EN 300 440,FCC Part 15,EN IEC 62311,IEC 62368-1,and EN 62368-1
RG-AP840-I(V2)
Dual radios, six spatial streams, peak data rate of 5.378 Gbps
● Radio 2: 5 GHz: four spatial streams, 4x4 MU-MIMO, peak data rate of 4.804 Gbps
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3at/bt PoE and local DC power supply
1000BASE-SX mini-GBIC module
1000BASE-LX mini-GBIC module
