RG-AP820-L(V2) Wireless - 1
RG-AP820-L(V2) Wireless - 2
RG-AP820-L(V2) Wireless - 3
RG-AP820-L(V2) Wireless - 4
RG-AP820-L(V2) Wireless - 5
RG-AP820-L(V2) Wireless - 6
RG-AP820-L(V2) Wireless - 7
RG-AP820-L(V2) Wireless - 8
RG-AP820-L(V2) Wireless - 9
RG-AP820-L(V2) Wireless - 10
Ideal for Various Scenarios
RG-AP820-L(V2) adopts a slim design to blend seamlessly into the environment,
which is ideal for various scenarios covering hotels, offices, and retail stores.
Wi-Fi 6 AX2400
Bluetooth 5.0
DC/PoE input
Free cloud management
Upgraded to Wi-Fi 6, Up to 2.402 Gbps Data Rate
2.4 Gbps
High Concurrency
High Rate
Low Latency
High Security
Superior Roaming Experience and Service Continuity
The built-in smart antennas can identify the directions of clients around the AP. Integrated with Ruijie's proprietary roaming algorithm, the AP also supports 802.11k/v/r. Intelligent channel planning and accurate wireless positioning enable clients to associate with the optimal AP.
Automatic Provisioning, Simplified Deployment
Ruijie's wireless controller delivers the configuration in batches, eliminating the need to pre-configure the AP before installation. This enables automatic provisioning and simplified deployment, reducing implementation and maintenance complexity.
Remote monitoring
Remote Wi-Fi management
Cloud portal authentication
RG-AP820-L(V2)
Unit dimensions (W x D x H)
153 mm x 193 mm x 26 mm (6.02 in. x 7.60 in. x 1.02 in.)
Shipping dimensions (W x D x H)
377 mm x 322 mm x 228 mm (14.84 in. x 12.68 in. x 8.98 in.)
Main unit: 0.42 kg (0.93 lbs)
Mounting bracket: 0.07 kg (0.15 lbs)
5.75 kg (12.68 lbs)
Wall/Ceiling-mount (a mounting bracket is delivered with the main unit.)
White
Securing latch and Kensington lock
RG-AP820-L(V2)
Dual-radio design and four spatial streams
● Radio 1: 2.4 GHz/5 GHz, two spatial streams, 2x2, MU-MIMO
● Radio 2: 5 GHz, two spatial streams, 2x2, MU-MIMO
Operating frequency bands
Radio 1:
802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz ISM, channels 1 to 13
802.11a/n/ac/ax:
Radio 2, 802.11a/n/ac/ax:
Note: Available frequency bands may vary with countries or regions. To use the above-mentioned frequency bands, ensure that they are supported in your country or region. For details, see For details, see WLAN Country or Region Codes and Channel Compliance.
Data rates
Combined peak data rate:
2.4 GHz + 5 GHz, 1.775 Gbps
5 GHz + 5 GHz, 2.402 Gbps
Radio 1:
2.4 GHz, 574 Mbps
● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client devices (maximum)
5 GHz, 1.201 Gbps
● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to individual 2SS HE80 802.11ax client device (maximum)
● Two spatial stream Single User (SU) MIMO for up to 574 Mbps wireless data rate to individual 2SS HE40 802.11ax client device (typical)
● Two spatial stream Multi-User (MU) MIMO for up to 1.201 Gbps wireless data rate to up to two 1SS HE80 802.11ax DL-MU-MIMO capable client devices simultaneously (maximum)
● Two spatial stream Multi-User (MU) MIMO for up to 574 Mbps wireless data rate to up to two 1SS HE40 802.11ax DL-MU-MIMO capable client devices simultaneously (typical)
Radio 2: 5 GHz, 1.201 Gbps
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
Packet aggregation
● 2 x 2.4 GHz antennas (Radio 1)
● 4 x 5 GHz antennas (Radio 1 & Radio 2)
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 5 dBi
Maximum transmit power
Note: The transmit power is limited by local regulatory requirements. For details, see For details, see WLAN Country or Region Codes and Channel Compliance.
Power increment
Radio technologies
802.11ax: OFDMA
802.11b: BPSK, QPSK, and CCK
802.11a/g/n: BPSK, QPSK, 16-QAM, and 64-QAM
802.11ac: BPSK, QPSK, 16-QAM, 64-QAM, and 256-QAM
802.11ax: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, and 1024-QAM
Wi-Fi Radio Performance
RG-AP820-L(V2)
–93 dBm
–93 dBm
–92 dBm
21 dBm
22 dBm
–87 dBm
22 dBm
–74 dBm
–87 dBm
19 dBm
–69 dBm
–84 dBm
19 dBm
–66 dBm
–87 dBm
15 dBm
–84 dBm
15 dBm
–56 dBm
21 dBm
–91dBm
21 dBm
–78dBm
19 dBm
–74 dBm
21 dBm
–87 dBm
–69 dBm
21 dBm
–84 dBm
–66 dBm
21 dBm
–87 dBm
17 dBm
–64 dBm
21 dBm
–84 dBm
17 dBm
–59 dBm
21 dBm
–81 dBm
17 dBm
–55 dBm
5 GHz 802.11ax (HE20)
21 dBm
–87 dBm
15 dBm
21 dBm
–84 dBm
15 dBm
–56 dBm
21 dBm
–81 dBm
15 dBm
Bluetooth Radio
RG-AP820-L(V2)
Bluetooth 5.0
Maximum antenna gain
4.5 dBi, with a downtilt angle of roughly 30 degrees
10 dBm
Receive sensitivity
–88 dBm (@BLE)
RG-AP820-L(V2)
1 x 10/100/1000BASE-T port
● Auto MDI/MDIX crossover
● PoE-PD: 54 V DC (nominal) 802.3af/at/bt (Class 3 or higher)
● 802.3az Energy Efficient Ethernet (EEE)
● Press the button for less than two seconds to restart the device.
● Press the button for more than five seconds to restore the device to factory settings.
RG-AP820-L(V2)
● 48 V DC/0.3 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased independently.
● PoE input over LAN/PoE: The power sourcing equipment (PSE) complies with IEEE 802.3af standard (PoE).
If both DC power and PoE are available, DC power is preferred.
Overall power consumption
● DC powered: 12.95 W
● Idle mode: < 8 W
RG-AP820-L(V2)
Basic Information
RG-AP820-L(V2)
RGOS 11.9(6)W3B1 or later
RG-AP820-L(V2)
Recommended maximum number of active devices per AP
120
 Note
Maximum number of BSSIDs
Layer 2 and Layer 3 roaming (supported only in Fit mode)
RG-AP820-L(V2)
PSK, PPSK, Web, 802.1X, PEAP, WPA, WPA2, and WPA3 authentication
Wireless intrusion detection system (WIDS)
Dynamic ACL assignment based on 802.1X authentication (The AP needs to work with an AC.)
CPU Protect Policy (CPP)
RG-AP820-L(V2)
Static IPv4 address
IPv4 DHCP client
FTP ALG and DNS ALG
IPv6 basics
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, and IPv6 ping
DHCP snooping, DHCP Option 82, DHCP server, and DHCP client
Dial-up Internet connection
Link Layer Discovery Protocol (LLDP)
LLDP-MED
LLDP-PoE
RG-AP820-L(V2)
NTP Server and NTP Client
Web-based management (Eweb)
Console, Telnet, SSH, SNMP, and TFTP-based management
Fat/Fit/Cloud mode switchover
When the AP works in Cloud mode, it can be managed through Ruijie Cloud.
RG-AP820-L(V2)
In compliance with IEEE 802.11a/b/g/n/ac and IEEE 802.11ax standards
Up to four spatial streams
Combined peak data rate of 2.402 Gbps
Fat/Fit mode switchover
IEEE 802.3af-compliant PoE and local power supply
● The PSE needs to be purchased separately.
● The local power adapter needs to be purchased separately. The output voltage and current need to be 48 V and 0.3 A, respectively.
RG-E-120(E)
PoE adapter:
1 x 1000BASE-T port
