RG-AP820-I Wireless - 1
RG-AP820-I Wireless - 2
RG-AP820-I Wireless - 3
RG-AP820-I Wireless - 4
RG-AP820-I Wireless - 5
Product Overview
The RG-AP820-I is a Wi-Fi 6 wireless access point that integrates dual radios, high performance, and enterprise-grade encryption technology. Due to the hybrid cloud management mode and high-density access design, it is suitable for flexible deployment in high-quality network scenarios, such as classroom, dormitory, and office scenarios in the education industry, production workshop and warehouse scenarios in the manufacturing industry, and outpatient clinics and mobile ward rounds scenarios in the medical industry.
Product Highlights
Ultra-High Performance
Dual-band design (2.4 GHz + 5 GHz), four spatial streams, 1024-Quadrature Amplitude Modulation (QAM) high-speed access, and up to 2.976 Gbps peak data rate, realizing high-speed wireless access experience
Orthogonal Frequency-Division Multiple Access (OFDMA), Multi-User Multiple-Input Multiple-Output (MU-MIMO), and Wi-Fi Multimedia (WMM), increasing the average rate per user in high-density deployment environments
RF power adjustment and intelligent channel allocation to solve the problems such as co-channel interference and adjacent channel interference, thereby improving network transmission efficiency and stability
Flexible Networking
Local and cloud management modes, and intelligent wireless network optimization, reducing TCO and maximizing ROI
Access through optical and Ethernet cables for flexible networking and high-speed backhaul over 2.5 Gbps optical links
IEEE 802.11k/v/r support and roaming stickiness optimization, achieving seamless user roaming
Rich IoT features: PoE output, Bluetooth 5.1, and wireless locating
High Security and Reliability
Encryption and authentication technologies including Wi-Fi Protected Access 3 (WPA3), enhanced open security, 802.1X, and Private Pre-shared Key (PPSK), enhancing data security
Dynamic Frequency Selection (DFS), optimizing the use of available RF spectrum to prevent radar channel interference
Cyclic Delay/Shift Diversity (CDD/CSD), Maximum Ratio Combining (MRC), Space-Time Block Coding (STBC), and Low-Density Parity Check (LDPC), improving the signal quality, signal receiving, and reliability and performance of data transmission
Transmit beam-forming (TxBF) expands the signal coverage and enhances the reliability of specific devices, thereby improving the data rate
Intelligent identification and monitoring, multicast-to-unicast conversion, and other features, enhancing network security and reliability
Product Features
Multi-scenario Adaptability
The RG-AP820-I, a dual-band wall-mounted wireless access point, is ideal for a wide range of applications, including higher education, government, general education, finance, and business sectors, providing flexible solutions to meet diverse service needs.
High-speed Access and Compatibility
The RG-AP820-I supports various wireless protocols, such as 802.11ax, 802.11ac Wave2, 802.11ac Wave1, and 802.11n. It features a hardware-independent dual-band design to deliver a data rate of up to 2.976 Gbps, effectively eliminating wireless performance bottlenecks. Additionally, it is compatible with an extensive array of devices, promoting seamless interconnectivity among employees and customers.
Security and Scalability
The RG-AP820-I stands out with its exceptional wireless network security, RF control, mobile access, QoS guarantee, and seamless roaming. With Ruijie's wireless access controller (AC), it enables wireless user data forwarding, security, and access control to cope with diverse service needs.
Flexible Deployment and Power Supply
The RG-AP820-I supports both local power supply and Power over Ethernet (PoE), providing you with the flexibility to choose the power supply mode. In addition, the RG-AP820-I can be mounted against a wall or ceiling, making space deployment and environmental requirements less challenging. This makes the RG-AP820-I particularly suitable for scenarios such as large campuses, conference centers, enterprise offices, and operation hotspots.
RG-AP820-I
Four spatial streams
Channels:
● Radio 2 – 5 GHz: 6.5 Mbps to 300 Mbps (MCS0 to MCS31)
Two spatial streams
Channels:
Channels:
Combined peak data rate: 2.976 Gbps:
● 2.4 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5 dBi.
● 5 GHz: two built-in omnidirectional smart antennas, with peak antenna gain of 5.7 dBi.
● One onboard omnidirectional antenna, with peak antenna gain of 2.4 dBi.
1 x 10/100/1000BASE-T port
1 x 2.5GE SFP/RJ45 combo port, compatibility with 1GE module, shared with one 10/100/1000BASE-T port
1 x Bluetooth 5.1
● Wireless user online status
● CAPWAP tunnel timeout
● Specific AP locating
Main unit: 220 mm x 220 mm x 49 mm (8.66 in. x 8.66 in. x 1.93 in.)
Shipping: 507 mm x 319 mm x 278 mm (19.96 in. x 12.56 in. x 10.94 in.)
Main unit: 0.6 kg (1.33 lbs)
Shipping: 1.04 kg (2.29 lbs)
● 48 V/0.6 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power supply needs to be purchased independently.
● DC power: 12.95 W
● 802.3bt (PoE++): 12.95 W
● 802.3at (PoE+): 12.95 W
● 802.3af (PoE): 12.95 W
● Idle mode: 6 W
Operating humidity: 0% RH to 95% RH (non-condensing)
512 MB DRAM, 128 MB flash
Transmit
power
2.4 GHz:
● Maximum transmit power: 26 dBm (398 mW)
5 GHz:
● Adjusting the transmit power by percentage (recommended) and in 1 dBm increments.
RG-AP820-I
2.4 GHz 802.11b
–90 dBm
–87 dBm
2.4 GHz 802.11g
22 dBm
22 dBm
–78 dBm
–72 dBm
2.4 GHz 802.11n (HT20)
19 dBm
–67 dBm
2.4 GHz 802.11n (HT40)
19 dBm
–64 dBm
2.4 GHz 802.11ax (HE20)
15 dBm
–58 dBm
2.4 GHz 802.11ax (HE40)
15 dBm
5 GHz 802.11a
22 dBm
22 dBm
–78 dBm
–72 dBm
5 GHz 802.11n (HT20)
19 dBm
–67 dBm
5 GHz 802.11n (HT40)
19 dBm
–64 dBm
5 GHz 802.11ac (VHT20)
5 GHz 802.11ac (VHT40)
–57 dBm
5 GHz 802.11ac (VHT80)
5 GHz 802.11ax (HE20)
–58 dBm
5 GHz 802.11ax (HE40)
5 GHz 802.11ax (HE80)
–52 dBm
5 GHz 802.11ax (HE160)
–77 dBm
–50 dBm
Basic Functions
RG-AP820-I
RGOS11.9(6)W1B4 or later
128
WLAN service
Maximum number of WLAN IDs: 16
Maximum number of associated STAs per WLAN: 32
MU device locating
Application management
PSK ,PPSK, UPSK, PEAP and web authentication
QR code-based guest authentication, SMS authentication, and MAC address bypass (MAB) authentication (used with RG-WS series ACs)
Dynamic Policy
ACL Remark
CoA/DM
MAC address table size: 1,024
Jumbo frame length: 1,518
Ethernet II frame format
1000M SFP ports
2.5GE interfaces
Maximum number of SVIs (IPv4): 200
Maximum number of SVIs (IPv6): 200
VLAN ID range: 1–4,094
NAT, FTP ALG and DNS ALG
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, IPv6 ping, IPv6 tracert
Maximum number of ND entries: 4,096
RG-WS series wireless controller and WIS Cloud
RG-AP820-I
Big data capabilities
RG-AP820-I
RG-AP820-I
Wi-Fi 6 (802.11ax) indoor wireless access point
802.11a/b/g/n/ac/ax, switching between Fat, Fit, and cloud modes, and 802.3af PoE and local DC power supply
● The power source equipment (PSE) needs to be purchased separately. The PoE Power Injector can be purchased from Ruijie.
● The DC power module has to be purchased separately from a third party. The output voltage/current must be 54 V/1.1 A.
RG-E-120(GE)
Single PoE Power Injector with 1000BASE-T support, supporting 802.3af
1000BASE-SX mini-GBIC module
1000BASE-LX mini-GBIC module
