RG-AP810-L Wireless - 1
RG-AP810-L Wireless - 2
RG-AP810-L Wireless - 3
RG-AP810-L Wireless - 4
RG-AP810-L Wireless - 5
RG-AP810-L Wireless - 6
RG-AP810-L Wireless - 7
RG-AP810-L Wireless - 8
RG-AP810-L Wireless - 9
Building a High-Speed and Efficient Network with Wi-Fi 6
Indoor Access Point RG-AP810-L
Wi-Fi 6
1.775 Gbps wireless throughput
PoE and DC power supply
Free cloud management
1.775 Gbps High Speed with Wi-Fi 6
High speed:
High concurrency:
OFDMA and MU-MIMO transfer technologies, 4x more concurrent users than Wi-Fi 5
High security:
Low latency:
OFDMA technology reduces the delay to as low as 20 ms, improving UX in video and audio services
1.775
Gbps
Intelligent Roaming Technologies, Full Wi-Fi Coverage
Intelligent roaming with 802.11k/v/r protocols, enabling clients to seamlessly access APs with stronger signals,
and achieving low roaming delay and zero stalling during roaming.
PoE and DC Power Supply, Flexible Deployment
With PoE in, a single network cable can transmit both data and power without external power supply.
With a 48V DC power supply, there's no need for PoE switches, reducing networking costs.
* Power adapters need to be purchased independently.
Remote monitoring
Remote Wi-Fi management
Standalone cloud portal authentication
RG-AP810-L
Unit dimensions(W x D x H)
514 mm x 326 mm x 294 mm (20.24 in. x 12.83 in. x 11.57 in.)
Device: 0.6 kg (1.33 lbs)
Mounting bracket: 0.2 kg (0.44 lbs)
8.45 kg (18.63 lbs)
Wall/Ceiling-mount (A mounting bracket is delivered with the main unit)
RG-AP810-L
Dual-radio
Radio 1: 2.4 GHz, two spatial streams, 2x2 MU-MIMO
Radio 2: 5 GHz, two spatial streams, 2x2 MU-MIMO
Operating frequencies
Radio 1, 802.11b/g/n/ax:
● 2.400 GHz to 2.4835 GHz, ISM
Radio 2, 802.11a/n/ac/ax:
● 5.150 GHz to 5.250 GHz, U-NII-1
● 5.250 GHz to 5.350 GHz, U-NII-2A
● 5.470 GHz to 5.725 GHz, U-NII-2C
● 5.725 GHz to 5.850 GHz, U-NII-3/ISM
Data rates
2.4 GHz radio, 574 Mbps
5 GHz radio, 1.201 Gbps
● Two spatial stream Single User (SU) MIMO for up to 1.201 Gbps wireless data rate to 2SS HE80 802.11ax client devices (typical)
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
● 802.11g: 1, 2, 5.5, 6, 9, 11, 12, 18, 24 ,36, 48, 54
● 802.11n: 6.5 to 300 (MCS0 to MCS15, HT20 to HT40)
● 802.11ax: 8.6 to 574 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE40)
5 GHz radio
● 802.11ac: 6.5 to 867 (MCS0 to MCS9, NSS = 1 to 4, VHT20 to VHT80)
● 802.11ax: 8.6 to 1,201 (MCS0 to MCS11, NSS = 1 to 2, HE20 to HE80)
Packet aggregation
802.11n/ac/ax: A-MPDU and A-MSDU
Built-in omnidirectional antennas (two 2.4 GHz antennas and two 5 GHz antennas)
Antenna gain
2.4 GHz: 2 dBi
5 GHz: 4 dBi
Maximum transmit power
Thailand
Power increment
Configurable based on requirement
Radio technologies
802.11b: BPSK, QPSK, CCK
802.11a/g/n: BPSK, QPSK, 16-QAM, 64-QAM
RG-AP810-L
–90 dBm
–87 dBm
22 dBm
22 dBm
–78 dBm
–72 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
15 dBm
–58 dBm
15 dBm
22 dBm
22 dBm
–78 dBm
–72 dBm
19 dBm
–67 dBm
19 dBm
–64 dBm
–57 dBm
–58 dBm
–52 dBm
Bluetooth Radio
RG-AP810-L
Bluetooth 5.1
1 x onboard built-in omnidirectional antenna
Maximum antenna gain
17 dBm (GFSK)
14 dBm (π/4-DQPSK, 8-DPSK)
Receive sensitivity
–95.5 dBm (DH5)
–95 dBm (π/4-DQPSK)
–87.5 dBm (8-DPSK)
Ports Specifications
RG-AP810-L
1 x 10/100/1000BASE-T port
● In compliance with IEEE 802.3af standard (PoE)
● Auto MDI/MDIX crossover
● 802.3az EEE
RG-AP810-L
● 48 V DC/0.3 A power input over DC connector: The DC connector accepts 2.1 mm/5.5 mm center-positive circular plug. A DC power adapter needs to be purchased separately.
● PoE input over PoE-in port: The power source equipment (PSE) complies with IEEE 802.3af standard (PoE).
Overall power consumption
● DC powered: 12.95 W
● Idle mode: 6 W
RG-AP810-L
Operating temperature: –10°C to +50°C (14°F to 122°F)
Storage Temperature: –40°C to +70°C (–40°F to +158°F)
RG-AP810-L
Security regulations
EN 62368-1
EMC regulations
EN 301 489-3
EN 301 489-17
Radio frequency regulations
EN 300 328
EN IEC 62311
FCC Part 15
Applicable Software Version
RG-AP810-L
AP_RGOS 11.9(6)W1B4 or higher
RG-AP810-L
64 (for HD Video)/120 (for general usage)
256
 Note
Maximum number of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
Security and Authentication
RG-AP810-L
PSK, web, 802.1X, PEAP, WPA, WPA2, and WPA3 authentication
Dynamic ACL assignment
Routing and Switching
RG-AP810-L
IP service
Static IPv4 address and DHCP-assigned IPv4 address
DHCP Snooping, Option 82, DHCP Server, DHCP Client
IPv6 basics
IPv6 DHCP Client
Dial-up Internet connection
PPPoE Client
RG-AP810-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Fat/Fit/Cloud mode switchover
Remarks
RG-AP810-L
Wi-Fi 6 (802.11ax) dual-radio indoor wireless access point
Up to four spatial streams
Data rate of up to 1.775 Gbps
1 x 10/100/1000Base-T uplink port, supporting PoE and DC power supply
Bundled with Ruijie Cloud Service lifetime license
 (The PoE injector is sold separately, which could be purchased from Ruijie.
The DC power adapter should be purchased from a third-party vendor separately if needed.)
Mandatory
RG-E-120(GE)
1-port PoE injector (1000BASE-T, IEEE 802.3af-compliant)
Optional
