RG-WS6512 Wireless - 1
RG-WS6512 Wireless - 2
RG-WS6512 Wireless - 3
RG-WS6512 Wireless - 4
Product Overview
The RG-WS6512, a high-performance wireless controller developed by Ruijie Networks, is a future-proof wireless network device that is suitable for higher education, general education, government, and financial scenarios. It can be seamlessly integrated into any Layer 2 or Layer 3 network without changing the existing network architecture or hardware devices, enabling secure wireless network control. The RG-WS6512 can manage 128 wireless access points (APs) by default. With license upgrade, it can manage up to 1,152 generic APs or 2,304 wall-mounted APs.
The RG-WS6512 can enable powerful centralized and visualized management and control, greatly simplifying implementation and deployment of wireless networks. With enhanced security and clustering technologies, the RG-WS6512 provides network services through identity-based networking, allows multiple wireless controllers to share user databases, and enables STAs to seamlessly roam across different areas of a network. This design ensures security and session integrity during mobile roaming, making it fit for data interaction and smooth voice services over Wi-Fi communication.
Product Highlights
Ultra-High Performance
High performance and high reliability: can be deployed on a Layer 2 or Layer 3 network to handle data exchange on all connected APs. Its intelligent local forwarding technology eliminates traffic bottlenecks and improves network performance.
Power redundancy and hot swapping: offers 1+1 redundancy and hot swapping of power modules, ensuring stable device operation and improving the availability of the system.
Intelligent RF management and network-wide seamless roaming: further enhances security and ensure efficient data transmission.
AC virtualization: virtualizes multiple ACs into one logical AC, realizing high reliability and capacity expansion without additional hardware devices.
Application traffic identification and application-level QoS mapping: identifies more than 2,500 applications through deep packet inspection, optimizes allocation of network resources, and enhances network performance.
Intelligent networking
DHCP security and managing information security: employs DHCP snooping to prevent the unauthorized DHCP server from allocating IP addresses, and uses SSH and SNMPv3 to encrypt management information, preventing hackers from attacking and controlling the device.
Rich management policies: supports multiple management modes, which can realize centralized, effective, and low-cost planning, deployment, monitoring, and management of APs on the entire network, and simplify network O&M.
Hierarchical AC management: uses the central AC to manage multiple branch ACs, improving the efficiency and reliability of network management.
Eweb-based management: provides Eweb, which is convenient for O&M personnel to plan, and operate and maintain a wireless network.
High Security
Virtual AP technology: allocates multiple SSIDs and configures separate authentication and encryption modes for each SSID to enhance security of a wireless network.
RF security: enables the RF probe scanning mechanism for connected APs to discover rogue APs or other RF interference sources in real time, ensuring security on a wireless network.
Virus and attack prevention: adopts multiple built-in security mechanisms to effectively prevent and control the spread of viruses and network traffic attacks, and to ensure network access of authorized users.
Secure user access: supports multiple easy-to-use authentication modes, including web authentication mode, 802.1X authentication, MAB authentication, and SMS- and QR code-based authentication, to enhance security of network access.
ARP anti-spoofing and AP containment: effectively prevents ARP spoofing and detects rogue APs to enhance security of a wireless network.
RG-WS6512
Number of manageable APs
128 (default), 2,304 (maximum)
Note: The number of APs that can be managed by the AC is subject to the AP model. See the Ordering Information for details.
4,096
32,768
Note: The maximum number of STAs that can be managed by the AC is subject to the network environment. Contact technical support team for details.
802.11 forwarding capacity
WLAN service
Maximum number of associated STAs per WLAN: 32,768
Number of VLANs
4 x 10GE SFP+ ports
8 x 1GE SFP/RJ45 combo ports, shared with one 10/100/1000BASE-T port
Port 1 can be used as an out-of-band management port
2 x USB ports
Power input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 10 A (steady state)
Power output: 12 V DC, 5.83 A
70 W
RGOS11.9(6)W1B1 or later
Web-based management (Eweb)
WIS-based management (RG-iData-WIS)
RG-Cloud
Hardware Specification
RG-WS6512
Main unit:5.9 kg (13.01 lbs)
Shipping: 7.03 kg (15.50 lbs)
1 x system status LED (under the Ruijie logo)
8 x 1GE RJ45 port LEDs
8 x 1GE SFP port LEDs
4 x 10GE SFP+ port LEDs
Operating temperature: 0°C to +45°C (32°F to 113°F)
Built-in fans
Right-to-left airflow
< 78 dB
400,000 hours (44 years) at the operating temperature of 25°C (77°F)
8 GB DRAM, eMMC 4 GB
RG-WS6512
802.11 protocols
Roaming
Intra-AC Layer 2 roaming
Inter-AC Layer 3 roaming
Intra-AC roaming handoff time < 50 ms
802.11R roaming in a VAC
802.11R roaming between ACs
Centralized forwarding
Local forwarding
Forwarding mode
Local forwarding
WLAN flexible forwarding (centralized forwarding is used for DHCP packets in local forwarding mode, and 802.1X/web/MAB authentication is not supported)
Wireless QoS
(WLAN/STA-based rate limit range: 8-261,120 in the unit of 8 Kbps. For example, if you set the value to 8, the rate limit is 8 x 8 Kbps = 64 Kbps.)
Intelligent and dynamic rate limiting based on channel utilization
Fair scheduling
Layer 2 user isolation in WIDS configuration mode
User isolation in a VLAN in local forwarding mode
AC virtualization
Maximum number of virtualized ACs : 4
AC failover
Multi-AC cluster (N-to-N)
Balanced access control based on the AP frequency band
WLAN optimization
RF management
Automatic selection of channel width
Band selection
IPv4 security authentication
MAB authentication
SMS authentication
Maximum number of STAs supported by the built-in Portal server: 7,500
IPv6 security authentication
Web authentication: IPv6 audit
802.1X authentication: IPv6 audit
Multi-SSID mode
WPA and WPA2
WEP (WEP/WEP128)
TKIP
CCMP
Anti-ARP spoofing
Maximum number of ACEs: 131,072
AP virtualization
Application Identification
Maximum number of MAC address entries: 131,072
Maximum number of ARP entries: 81,920
IPv4 protocols
Ping and traceroute
DHCP address pools
● Maximum number of IPv4 address pools: 2,000
● Maximum number of IPv4 addresses: 81,920
DNS client
NTP
Telnet
TFTP server and TFTP client
FTP server and FTP client
Neighbor discover
IPv6 protocols
DNSv6 client
DHCPv6 relay, DHCPv6 server, and DHCPv6 client
DHCP address pools
● Maximum number of IPv6 address pools: 256
● Maximum number of IPv6 addresses: 2,048
TFTPv6 client
FTPv6 server and FTPv6 client
IPv6 CAPWAP
IPv6 ping
6 over 4 manual tunnels, 6 to 4 automatic tunnels, and ISATAP
IPv6 traceroute
Neighbor discovery
IPv4 routing
Static routing, RIP, and OSPFv2
IPv4 routing entries: 8,192
IPv6 routing
Static routing, RIPng, OSPFv3
IPv6 routing entries: 10,000
Maximum number of static routing entries: 2,048
Maximum number of multicast group routing entries: 4,096
Management and Maintenance
RMON
Syslog
Console port login,Telnet login,SSH login,and FTP upload
The following value-added software functions can be achieved with the WIS solution (used with RG-iData-WIS and AP).
RG-WS6512
Big data capabilities
RG-WS6512
IEC 62368-1, EN 62368-1, EN 55032, EN 55035, EN 61000-3-3, EN IEC 61000-3-2, and ETSI EN 300 386
  • Order an RG-WS6512.
  • The RG-WS6512 supports up to 128 APs by default. To increase the number of supported APs, purchase the corresponding license.
  • The RG-WS6512 is configured with one power module during factory delivery. If more power modules are required, purchase the RG-PA70I power module separately.
    Main Unit and Accessories
RG-WS6512
The wireless controller provides 8 x combo ports and 4 x SFP+ 10GE ports.
●     A generic AP occupies one license. The RG-WS6512 can manage up to 1,152 generic APs.
●     A wall plate AP occupies half of the license. The RG-WS6512 can manage up to 2,304 wall plate APs.
●     An i-Share micro AP occupies no license. The RG-WS6512 can manage up to 2,304 i-Share micro APs.
●     The number of licenses occupied by an i-Share master AP is subject to the model. See the ordering information in the datasheet of corresponding i-Share master AP for details.
RG-PA70I
Optical Modules
Mini-GBIC-SX-MM850
1000BASE-SX mini-GBIC module
Mini-GBIC-LX-SM1310
1000BASE-LX mini-GBIC module
10GE SFP+ SR module
10GE SFP+ LR module
Licenses
RG-LIC-WS-16
The number of capacity expansion licenses for the RG-WS series wireless controller can be expanded to 16. Each license supports one generic AP or two wall plate APs. For the number of licenses occupied by an i-Share master AP, see the ordering information.
RG-LIC-WS-32
The number of capacity expansion licenses for the RG-WS series wireless controller can be expanded to 32. Each license supports one generic AP or two wall plate APs. For the number of licenses occupied by an i-Share master AP, see the ordering information.
RG-LIC-WS-128
The number of capacity expansion licenses for the RG-WS series wireless controller can be expanded to 128. Each license supports one generic AP or two wall plate APs. For the number of licenses occupied by an i-Share master AP, see the ordering information.
RG-LIC-WS-512
The number of capacity expansion licenses for the RG-WS series wireless controller can be expanded to 512. Each license supports one generic AP or two wall plate APs. For the number of licenses occupied by an i-Share master AP, see the ordering information.
RG-LIC-WS-1024
The number of capacity expansion licenses for the RG-WS series wireless controller can be expanded to 1,024. Each license supports one generic AP or two wall plate APs. For the number of licenses occupied by an i-Share master AP, see the ordering information.
