RG-S6580-48CQ8QC Switches - 1
RG-S6580-48CQ8QC Switches - 2
RG-S6580-48CQ8QC Switches - 3
RG-S6580-48CQ8QC Switches - 4
RG-S6580-48CQ8QC Switches - 5
RG-S6580-48CQ8QC Switches - 6
RG-S6580-48CQ8QC Data Center 100G High-Density Fixed Access Switch with 400GE Uplink(Backward Compatibility with 100GE)
High-density 400GE/100GE ports, supporting high-bandwidth and large-capacity server access
  • Various ports, and 48 x 100GE DSFP and 8 x 400GE QSPF-DD ports, supporting flexible networking
  • Hardware-level redundancy, ensuring nonstop services
  • Lossless Ethernet, ensuring zero packet loss in RDMA E2E communication
  • Telemetry network monitoring and automatic O&M, making management simple and efficient
Data Center 100GE Access Switch RG-S6580-48CQ8QC
The RG-S6580-48CQ8QC is a high-density access switch and provides various ports within the space of 1 RU. With improved data forwarding capabilities, it can be flexibly deployed and supports access of 100G servers. It can evolve to 100GE/400GE data centers.
Hardware-Level Redundancy, Ensuring Nonstop Services
1+1 power modules, hot swapping, and service failover within seconds, ensuing service continuity
Lossless Ethernet, Ensuring Zero Packet Loss in RDMA E2E Communication
With RDMA enabled, communication data on the RG-S6580-48CQ8QC does not need to be handled by the CPU. This reduces the burden of the CPU and effectively resolves the latency problem. Using PFC and ECN, the RG-S6580-48CQ8QC intelligently exchanges data to prevent packet loss and ensures lossless data transmission.
Telemetry Network Monitoring and Automatic O&M, Making Management Simple and Efficient
RG-S6580-48CQ8QC enabled with Telemetry uses the push mode to proactively collect and push information and provides sub-second-level network monitoring in real time, making network management more efficient and accurate.
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
442 mm x 670 mm x 43.6 mm (17.40 in. x 26.38 in. x 1.72 in.)
11.5 kg (25.35 lbs., a chassis with two power modules and six fan modules)
11 kg (24.25 lbs., a chassis with two power modules and six fan modules)
16.0 Tbps
16.0 Tbps
5350 Mpps
5350 Mpps
Service port
48 x 100G DSFP ports
8 x 100G/400G QSFP-DD ports
24 x 40G/100G/200G QSFP56 ports
Management port
6 x fan module slots
Maximum power consumption: 742 W
Typical power consumption: 633 W
Static power consumption: 178 W
Maximum power consumption: 850 W
Typical power consumption: 700 W
Static power consumption: 300 W
RG-PA1200I-F (AC input)
Rated input voltage:
100 V AC to 127 V AC, 200 V AC to 240 V AC, 50 Hz/60Hz
Maximum input voltage:
90 V AC to 140 V AC, 180 V AC to 264 V AC, 47 Hz to 63 Hz
Rated input current:
13.8 A(100 V AC to 127 V AC)
8.5 A (200 V AC to 240 V AC)
Power port type: C14
RG-PA1200I-F (HVDC input):
Rated input voltage: 240 V DC
Rated current: 6.5 A
RG-S6580-48CQ8QC
RG-S6580-24DC8QC
Layer 2 Protocols
IEEE 802.3x, IEEE 802.3ad (Link Aggregation Control Protocol), IEEE 802.1p, IEEE 802.1Q, IEEE 802.1D (STP), IEEE 802.1w (RSTP), IEEE 802.1s (MSTP), Jumbo Frame (9 KB)
Layer 3 Protocols (IPv4)
IPv6 Basic Protocols
IPv6 Features
Data Center Features
RDMA
VXLAN bridge
VXLAN gateway
IPv6 VXLAN over IPv4
IPv4 VXLAN over IPv4
ECN over VXLAN
PFC over VXLAN
Visualization
sFlow sampling
IPFIX
Priority marking/remarking
HA Design
Security Features
Network foundation protection policy (NFPP), CPP, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, plaintext-based and MD5 ciphertext-based authentication for OSPF, and BGPv4 packets, telnet login and password mechanisms for restricted IP addresses, broadcast packet suppression, hierarchical user management
Management Mode
SNMP v1/v2c/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and temperature alarm
Other Protocols
Chassis, Fan Module
RG-S6580-48CQ8QC
48 × 100GE DSFP ports + 8 × 400GE QSFP-DD ports
Two power slots and six fan slots
The chassis is installed with two RG-PA1200I-F modules and six M1HFAN II-F fan modules.
RG-S6580-24DC8QC
24 × 200GE QSFP56 ports + 8 × 400GE QSFP-DD ports
Power Supply Module
RG-PA1200I-F
1200 W AC module (AC/240 V HVDC)
Fan Module
M1HFAN II-F
Fan module (front-to-rear ventilation)
100GE Optical Transceivers
400GE Optical Transceivers
400G-QDD-SR8-MM850
400G-QDD-DR4-SM1310
400G-QDD-FR4-SM1310
400G FR4 module, QSFP-DD form factor, Duplex LC, 1310 nm, 2 km (6,561.68 ft.) over SMF
*400G-QDD-ZR-SM1550
400G ZR optical transceiver, QSFP-DD, Duplex LC, 1550 nm, 80 km (262,467.19 ft.) over SMF
