RG-N18006-X Switches - 1
RG-N18006-X Switches - 2
RG-N18006-X Switches - 3
RG-N18006-X Switches - 4
RG-N18006-X Switches - 5
RG-N18006-X Switches - 6
RG-N18006-X Switches - 7
RG-N18006-X Switches - 8
RG-N18006-X Switches - 9
RG-N18006-X Switches - 10
RG-N18006-X Switches - 11
100GE Data Center Modular
Core Switch RG-N18006-X
Line cards:
  • M18000X-48DC-CE:
  • M18000X-48CQ-CE:
  • M18000X-36QXS-CB:
  • M18000X-48XS2CQ-CB:
De-stacking
M-LAG
Clos architecture
RG-N18018-X
RG-N18010-X
RG-N18006-X
21 RU
12 RU
7 RU
12.88 kg (28.40 lbs., a chassis with three fan modules)
307.2 Tbps
153.6 Tbps
28.8 Tbps
69,120 Mpps
34,560 Mpps
17,280 Mpps
Module slots
2 x supervisor module slots
16 x line card slots
16 x power module slots
8 x line card slots
8 x power module slots
4 x line card slots
4 x power module slots
RG-PA2700I (AC input)
Rated input current: 16 A
Power port type: C20
RG-PA2700I (HVDC input):
Rated input voltage: 240V DC
RG-PD2400I (DC input):
Rated input current: 60 A
RG-PA3000I-F (AC input)
RG-PA3000I-F (HVDC input):
RG-N18018-X
RG-N18010-X
RG-N18006-X
Virtual Switching Unit 3.0
Data center features
VXLAN bridge
VXLAN gateway
BGP-EVPN VXLAN
VXLAN mapping
IPv6 VXLAN over IPv4
M-LAG
SDN
OpenFlow 1.3.
Traffic analysis
IPFIX
NetFlow
Layer 2 features
Jumbo frame
IEEE 802.1Q
STP, RSTP, MSTP
QinQ
IPv4 features
Policy-based routing
IPv6 features
VRRPv3
IGMP v1/v2/v3
IGMP Snooping
IGMP Proxy
MLDv1, MLDv2
Multicast static routing
Fast leave
Ingress/Egress ACLs
IPv6 ACLs
Priority marking/remarking
Port-based rate limit
Hot swapping of components
Hot patching
ISSU
NSR
FRR
GR for OSPF/IS-IS/BGP
uRPF
Source IP address restriction
ITU-T Y.1731
FTP, TFTP, Xmodem, and SFTP
SNMP V1/V2c/V3
RMON
NTP clock
Fault alarm and auto-recovery
Traffic analysis
Zero-touch provisioning (ZTP)
Telemetry
RG-N18018-X
RG-N18010-X
RG-N18006-X
M18000X-CM II
M18006X-CM II
M18000X-CM X
Power Modules
RG-PA2700I
RG-PA3000I-F
RG-PD2400I
Switch Fabric Modules
M18018X-FE-C II
M18018X-FE-C V
M18010X-FE-C I
M18010X-FE-C II
M18006X-FE-C I
M18006X-FE-E I
M18010X-FE-E II
M18018X-FE-E IV
Line Cards
M18000X-36QXS-CB
M18000X-36CQ-CB
M18000X-18CQ-CB
M18000X-18QXS18CQ-CB
M18000X-48XS2CQ-CB
M18000X-48CQ-CE
M18000X-48DC-CE
40G Optical Transceivers
100G Optical Transceivers
1000M Optical Transceivers
1000M Copper Transceivers
10GE Optical Transceivers
XG-LR-SM1310
XG-SR-MM850
10G SFP+ AOC, 5 m (16.40 ft.)
10G SFP+ AOC, 3 m (9.84 ft.)
10G SFP+ AOC, 1 m (3.28 ft.)
