| Feature |
RG-S6150-X Series |
| Ethernet switching |
| IEEE 802.1Q (supporting 4K VLANs) |
| Maximum number of VLANs that can be created: 4,094 |
| Voice VLAN |
| MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
| GVRP |
| Basic QinQ and selective QinQ |
| STP (IEEE 802.1.d), RSTP (IEEE 802.1w), and MSTP (IEEE 802.1s) |
| ERPS (G.8032) |
| LACP (IEEE 802.3ad) |
| LLDP/LLDP-MED |
| Non blocking |
| IP service |
Static and dynamic ARP |
| DHCP server, DHCP client, DHCP relay, and DHCP snooping |
| DNS |
| DHCPv6 server, DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping |
| GRE tunnel |
| IP routing |
Static routing |
| SVI: 4k supported |
| RIP and RIPng |
| OSPFv2 and OSPFv3 |
| GR |
| IS-ISv4 and IS-ISv6 |
| BGP4 and BGP4+ |
| Equal and Weighted Cost Multi-Path (ECMP) |
| Packet-based and flow-based load balancing |
| MCE |
| Stateless auto configuration |
| IPv4/IPv6 VRF |
| IPv4/IPv6 PBR |
| Multicast |
IGMPv1/v2/v3 and IGMP proxy |
| IGMPv1/v2/v3 snooping |
| IGMP filtering and IGMP fast leave |
| PIM-SSM for IPv4 and IPv6 |
| MSDP for inter-domain multicast |
| MLDv1/v2 |
| MLD snooping |
| MSDP |
| PIM-SMv6 |
| Multicast querier |
| MPLS |
MPLS L3VPN |
| 6PE/6VPE interconnection with IPv4/IPv6 MPLS backbone network |
| MPLS MIB (RFC1273, 4265, 4382) |
| ACL and QoS |
Standard IP ACLs (hardware ACLs based on IP addresses) |
| Time-based ACLs |
| ACL80 and IPv6 ACL |
| ACL redirection |
| Port traffic identification |
| Port traffic rate limiting |
| 802.1p/DSCP/ToS traffic classification |
| Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences |
| Eight queues on each port |
| Rate limiting in each queue |
| L2/L3/L4 packet identification and classification |
| Security |
Multi-AAA |
| RADIUS and TACAS+ |
| Filtering of invalid MAC addresses Broadcast storm suppression BPDU guard |
| Port- and MAC address-based 802.1x authentication |
| Web authentication |
| Hypertext Transfer Protocol Secure (HTTPS) |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| ICMPv6 |
| IPv6 addressing and Path MTU Discovery |
| IP source guard |
| SAVI |
| ARP spoofing prevention |
| CPP and NFPP |
| Various attack defense functions including NFPP, ARP anti-spoofing, DHCP/DHCPv6 attack defense, ICMP attack defense, ND attack defense, IP scanning attack defense, and customizing attack defense packet types |
| 3-tuple binding (IP address, MAC address, and port) ARP spoofing prevention 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression SSH BPDU guard |
| Loose and strict RPF uRPF ignoring default routes |
| Reliability |
REUP |
| ERPS (G.8032) |
| RLDP |
| RLDP, Layer 2 link connectivity detection, unidirectional link detection, and VLAN-based loop control |
| Data Link Detection Protocol (DLDP) |
| BFD |
| Link monitoring, fault notification, and remote loopback based on 802.3ah (EFM) |
| GR for RIP, OSPF, BGP, and other routing protocols Power modules in 1+1 redundancy mode Hot swapping of power modules and fan modules |
| Hot swapping of fan modules |
| Device virtualization |
VSU |
| NMS and maintenance |
SPAN, RSPAN, and ERSPAN |
| sFlow |
| NTP an SNTP |
| FTP and TFTP |
| SNMP v1/v2/c3 |
| RMON (1, 2, 3, 9) |
| Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups RMON used to implement Ethernet statistics, historical statistics, and alarm functions |
| NETCONF |
| Flow-based mirroring, and N:1 and 1:N port mirroring |
| CWMP |
| gRPC |
| CLI (Telnet/console), SSH, Syslog, SNMP over IPv6, Telnet v6, FTP/TFTP v6, DNS v6, and NTP for IPv6 |
| Ruijie Could-based management |
| VXLAN |
EVPN VXLAN tunnel establishment LAN access to VXLAN IPv4 over IPv4 Distributed gateway IPv6 over IPv4 Using an SVI to connect to the VXLAN network Using a routed interface to connect to the VXLAN network Proxy ARP (replying with the actual MAC address)) ND proxy (replying with the actual MAC address) ND reply (replying with the actual MAC address) EVPN VXLAN VXLAN static route Anycast gateway VXLAN bridging mode VXLAN routing mode Proxy ARP (replying with the gateway MAC address) Configuring the UDP port number in VXLAN packets Static VXLAN tunnel creation |
