2.5G-SFP-LX03-SM1310-BIDI-I Switches - 1
2.5G-SFP-LX03-SM1310-BIDI-I Switches - 2
2.5G-SFP-LX03-SM1310-BIDI-I Switches - 3
2.5G-SFP-LX03-SM1310-BIDI-I Switches - 4
2.5G-SFP-LX03-SM1310-BIDI-I Switches - 5
2.5G-SFP-LX03-SM1310-BIDI-I Switches - 6
Optical Module Specifications
3.125 Gbps
FB
3 km (9,842.52 ft.)
1 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–9 dBm
Min. extinction ratio
6.5 dB
< –16 dBm
–3 dBm
35 g (0.08 lbs.)
